F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 6m 21d Gender: Male Location: Strapped in and holding on Posted 17/01/07 08:35 AM Share Posted 17/01/07 08:35 AM That's odd, why would the tornado software be different to the typhoon software? Something to do with no TC on the ute?←Utes now have TC..Good work Al, iron out the bugs.. Considering " It couldn't be done " a few bugs is stuff all!!.Well done. Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487338 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 6m 13d Gender: Male Location: Perth, WA Posted 17/01/07 09:47 AM Author Share Posted 17/01/07 09:47 AM (edited) So the car is home again BUT I had to limp it home in 3rd all the way, as we have some software incompatibility between my BF F6 PCM software, and the BF Tornado TCM (transmission) software.I will have to wait until we can get our hands on a 6 speed BF XR6T, so we can 'suck' the program out of the PCM on that car, and feed it to mine.Other than that I have a brake issue, where the new BF master cylinder does not release pressure to the front wheels properly, so the brakes are dragging, unless I manually relieve the pressure by unscrewing the brake pipe.So I'm 95% there, but just have to sort out these last issues.←Whats causing the brake drag issue Al..? Do the ba and bf's have the same booster push rod length?←Ought to give you a medal Turns out that that was exactly what the problem was, identical cylinders, EXCEPT the push rod is shorter on a BF, and thus the hole in the base of the Master Cylinder piston is deeper on BA, so that was an easy fix Edited 17/01/07 09:47 AM by Ninka Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487378 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 6m 13d Gender: Male Location: Perth, WA Posted 17/01/07 09:49 AM Author Share Posted 17/01/07 09:49 AM That's odd, why would the tornado software be different to the typhoon software? Something to do with no TC on the ute?←Utes now have TC..Good work Al, iron out the bugs.. Considering " It couldn't be done " a few bugs is stuff all!!.Well done. ←Confirmed, as I have the ABS modulator from the Tornado, and it is TC enabled. Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487380 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 17d Gender: Male Location: Zombie Birdhouse Posted 17/01/07 10:16 AM Share Posted 17/01/07 10:16 AM Your nearly there Whiskas, keep the faith Your ongoing project is one of the most inspirational I have seen on these forums Given what you have been doing yourself ...... truly outstanding. I tips me hat to you Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487396 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 13d Gender: Male Location: Perth Posted 17/01/07 10:44 AM Share Posted 17/01/07 10:44 AM So the car is home again BUT I had to limp it home in 3rd all the way, as we have some software incompatibility between my BF F6 PCM software, and the BF Tornado TCM (transmission) software.I will have to wait until we can get our hands on a 6 speed BF XR6T, so we can 'suck' the program out of the PCM on that car, and feed it to mine.Other than that I have a brake issue, where the new BF master cylinder does not release pressure to the front wheels properly, so the brakes are dragging, unless I manually relieve the pressure by unscrewing the brake pipe.So I'm 95% there, but just have to sort out these last issues.←Whats causing the brake drag issue Al..? Do the ba and bf's have the same booster push rod length?←Ought to give you a medal Turns out that that was exactly what the problem was, identical cylinders, EXCEPT the push rod is shorter on a BF, and thus the hole in the base of the Master Cylinder piston is deeper on BA, so that was an easy fix ←Hey i try..... Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487411 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 19y 15d Gender: Male Posted 17/01/07 11:34 AM Share Posted 17/01/07 11:34 AM That's odd, why would the tornado software be different to the typhoon software? Something to do with no TC on the ute?←Utes now have TC..Good work Al, iron out the bugs.. Considering " It couldn't be done " a few bugs is stuff all!!.Well done. ←They have different software as utes & sedans have different weight distributions / wheel base lengths Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487428 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 6m 13d Gender: Male Location: Perth, WA Posted 17/01/07 12:47 PM Author Share Posted 17/01/07 12:47 PM Thanks for all the encouraging feedback, it is really appreciated, and helps me to push on when new obstacles are placed in front of me I WANT THIS TO BE COMPLETED SUCCESSFULLY and soon as well Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487450 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 20y 13d Gender: Male Posted 17/01/07 11:28 PM Share Posted 17/01/07 11:28 PM congratulations on the progress to this point!glad the brake issue wasn't a big problem not too much longer now..keep us posted!Your nearly there Whiskas, keep the faith Your ongoing project is one of the most inspirational I have seen on these forums Given what you have been doing yourself ...... truly outstanding. I tips me hat to you ←amen to that! Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487517 Share on other sites More sharing options...
Guest Guests Posted 18/01/07 01:23 AM Share Posted 18/01/07 01:23 AM So the car is home again BUT I had to limp it home in 3rd all the way, as we have some software incompatibility between my BF F6 PCM software, and the BF Tornado TCM (transmission) software.I will have to wait until we can get our hands on a 6 speed BF XR6T, so we can 'suck' the program out of the PCM on that car, and feed it to mine.Other than that I have a brake issue, where the new BF master cylinder does not release pressure to the front wheels properly, so the brakes are dragging, unless I manually relieve the pressure by unscrewing the brake pipe.So I'm 95% there, but just have to sort out these last issues.←How do you go about sucking the software out and installing it back into your box, will that leave the other ZF programless. Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487563 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 6m 13d Gender: Male Location: Perth, WA Posted 18/01/07 01:36 AM Author Share Posted 18/01/07 01:36 AM As I understand it, you can't such the programme from the TCM, but only from the PCM, so the trans stays as it came out of the factory. Link to comment https://www.fordxr6turbo.com/forum/topic/30284-ba-to-be-bfed/page/16/#findComment-487565 Share on other sites More sharing options...
