Ba To Be Bf'ed
Ninka
  • Member For: 21y 10m 29d
Complete harness for lhs of vehicle
There are additional wires associated with the 6 speed shifter in the loom, and I did not want to go chopping and adding wires to the loom, but opted for a factory complete loom, this is true of the dash and rhs loom as well
Complete dash harness
ABS modulator unit - BF use a different ABS modulator, and it has a different plug on it, so to make it connect to the lhs engine bay loom, it had to be changed.
BF Master Brake cylinder
The BA unit has 2 different size brake pipes, and thus thread sizes, a BF F6 has 2 large ones.
Change transducer for Power Steering
BF has 3 wires on the tranducer, where BA has only 2
Steering column with BF ignition lock
Apparently the BF runs a different security system, and I did not want to chance the BA key not working in this system,
Door barrel
Now use the same key as ignition
Glovebox lock and handle
BF Alternator + new rear bracket for same
BF has a 'smart' alternator, which has 3 wires and a different plug on the regulator, and thus the BA loom cannot be used. Also the Fuse Box in the engine bay would not be configured for a BA alternator plug to plug in.
New BF Alternator harness
Same as above
Hey mate just a quick question but why do the items I've quoted need to be replaced?
How much was the complete engine bay harness and 2 side harness's?
I agree that some of the parts may have been unnecessary, and the rhs/lhs wiring looms could probably have been modified to to work, but I have opted to make a complete transformation, to make my car to the same specs as an 04/2006 BF F6, and in doing so, keep things EXACTLY as they would be on that model vehicle.
Thanks for the interest :spoton:
Thanks for the info, very intresting.
Did you buy the looms new or did you buy them from a wrecker's, is it a big job to replace all the looms in a car like you have.
  • Formerly Turbo6
  • Member For: 21y 10m 14d
And here I am whinging about some pipes that will not fit my new turbo and other trivial little stuff................... :blink:
Crikey, I would hate to be doing this! :yikes:
It was a combination, with most coming new from Ford, and the dash loom and lhs engine bay loom coming from a wrecker.
Danm right it is a big job to replace the looms, and the scratches on my hands have only just healed from fitting the engine loom, what a b*tch :spit:
What are the looms worth new, I have a ba xr8 shell I'd like to possibly do this to. It has had both fuse boxe's ripped out and needs a bit of work.
I'd probally just pay my auto elec to fit it all as it's a bare shell, all that's left is the roof lining.
Danm right it is a big job to replace the looms, and the scratches on my hands have only just healed from fitting the engine loom, what a b*tch :spoton:
Most of the looms are in the $350 - $550 range ea, except for the dash loom, which I think was about $800 new. Considering the amount of wiring and plugs involved, I didn't consider the cost unreasonable
Good luck with your project.
My car is at Ford to get all the programmes loaded, so in the next day or so I hope to be driving it again :spoton:
  • Member For: 20y 1m 20d
Allan,
Fantastic effort, I love reading your techo mad posts. So the car is now almost completely a BF ?? What's next ... I don't think there is much more you can do !!! Maybe 4WD.....
Cheers
Robin.
