O2STOCK Donating Members 607 Member For: 19y 3m 29d Location: Brisbane Posted 08/11/06 12:50 PM Share Posted 08/11/06 12:50 PM Well that clears that up then Link to comment Share on other sites More sharing options...
Guest Guests Posted 08/11/06 01:01 PM Share Posted 08/11/06 01:01 PM [quote name='Headsex' date='Nov 8 2006, 09:52 PM']I'm not taking offence, i'm tring to clear things up, but i only quoted Mototron as i assumed they were the same injector.. ie "Siemens/MotoTron Deka 60lb".. Everywhere i googled suggested they were the same, Hense why i quoted it. The car is v8capri's, his supercharged V8 GROUP-A, alot of people have seen it at various dyno shootouts, and correction to my original post of 550rwkw, it is 506rwkw. Eitherway, These are Siemens Deka 60lb babies. Look at my attached picture, no sign of MOTOTRON printed on.. even if the mototron are chinese copies.. Dan. [right][snapback]461661[/snapback][/right] [/quote] well thats good then if there not mototron cause then there very cheep!!!! you just got me worried that there cheepies and all i said was ill find out from seimens vdo what the story is as the yanks bagged the mototron's Link to comment Share on other sites More sharing options...
XR6TT Member 69 Member For: 19y 7m 22d Location: VIC Posted 08/11/06 03:14 PM Share Posted 08/11/06 03:14 PM intresting. good to know! Link to comment Share on other sites More sharing options...
PumpedUp Member 90 Member For: 18y 5m 29d Location: Mehico Posted 08/11/06 03:36 PM Share Posted 08/11/06 03:36 PM If these are GENUINE Siemens Deka IV Injectors at that price, you can put me down for a set! How soon can we get these? Link to comment Share on other sites More sharing options...
spine Donating Members 642 Member For: 18y 8m 25d Gender: Male Location: Footscrayastan Posted 08/11/06 07:37 PM Share Posted 08/11/06 07:37 PM is everyone clear now as to what is on offer??? LOL!! Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 2d Gender: Male Location: Melb Posted 08/11/06 08:38 PM Author Share Posted 08/11/06 08:38 PM [quote name='PumpedUp' date='Nov 9 2006, 01:36 AM']If these are GENUINE Siemens Deka IV Injectors at that price, you can put me down for a set! How soon can we get these? [right][snapback]461728[/snapback][/right] [/quote] As soon as there is 10 people, and they have all paid up. dan Link to comment Share on other sites More sharing options...
Evil F6 Donating Members 830 Member For: 19y 3d Gender: Male Location: Sydney Posted 09/11/06 12:33 AM Share Posted 09/11/06 12:33 AM [quote name='Headsex' date='Nov 9 2006, 06:38 AM'][quote name='PumpedUp' date='Nov 9 2006, 01:36 AM']If these are GENUINE Siemens Deka IV Injectors at that price, you can put me down for a set! How soon can we get these? [right][snapback]461728[/snapback][/right] [/quote] As soon as there is 10 people, and they have all paid up. dan [right][snapback]461738[/snapback][/right] [/quote] I'll be away for a couple of weeks from the 17th of this month, so if I'm away and you don't hear from me don't assume I've pulled out. Don't worry about these injectors being too big for cars say under 300rwkW, as they have excellent low flow characteristics even under small pulse widths; According to lingenfelter's website here is a blurb about the deka inkjectors: [quote][color=yellow]Despite the high flow rate, these injectors provide a very linear flow rate even at low pulse widths allowing you to use a larger injector than normally possible without hurting idle and low speed driveability. These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures. These injectors are the perfect upgrade for stock manifold & rail assemblies; replacing standard 75 mm packaged injectors. Also recommended for use in custom manifolds where optimum injector targeting requires more length. Engine performance and running quality is enhanced through the optimized spray pattern of these injectors. Unlike many “pencil stream” high flow injectors, these high flow injectors utilize a multi-orifice tip providing a true 30 degree spray pattern for improved mixture preparation. This results in lower BSFC and better idle quality than many injectors of less flow.[/color] [/quote] Link to comment Share on other sites More sharing options...
Basketballer_vince Member 136 Member For: 20y 4m 24d Gender: Male Location: Melbourne Posted 09/11/06 05:38 AM Share Posted 09/11/06 05:38 AM when you get to 9 send me a msg and i'll see if i have the cash. Link to comment Share on other sites More sharing options...
Robit28 Member 385 Member For: 19y 2m 13d Location: Brisbane Posted 09/11/06 05:51 AM Share Posted 09/11/06 05:51 AM What sort of warranty do they have and where do we send them back if there is a problem? Will there be a tax invoice? At least with Nick I am safe if I ever have a problem. Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 2d Gender: Male Location: Melb Posted 09/11/06 06:05 AM Author Share Posted 09/11/06 06:05 AM [quote name='Robit28' date='Nov 9 2006, 03:51 PM']What sort of warranty do they have and where do we send them back if there is a problem? Will there be a tax invoice? [/quote] These are brand new, as for warentee, i've just fired a email off, and awaiting reply. Either way, if you have any problems in the future i can help out. As for tax invoice, there will be one covering the bulk purchase of injectors.. What normally happens here in a bulk buy? Dan. Link to comment Share on other sites More sharing options...
