Siemens Deka 60lb Injectors! My Lastest Mod - Possibly group purchase?
Headsex
  • Replies 139
  • Member For: 19y 5m 11d
[quote name='O2STOCK' date='Nov 8 2006, 09:04 PM']Are these the same as the ones Nicks selling ?
If so Ill take a set at that price
[right][snapback]461637[/snapback][/right]
[/quote]
Can assure you they will be fine.
So far the list stands as
Evil F6
ForcedXR6
Jaeyon
O2STOCK
need 10 sets to get $75 each price each
[quote name='DBOSS' date='Nov 8 2006, 09:23 PM']Put me down for two sets
CYA JEFF :roflmbo:
[right][snapback]461642[/snapback][/right]
[/quote]
2 sets of 6? or 2 sets of 8 ?? :)
Dan
[quote name='Headsex' date='Nov 8 2006, 08:52 PM'][quote name='Dynowog' date='Nov 8 2006, 08:48 PM']ahh but the reliability is it the same?
confident though if no mototron on them they should be fine but ill check as i said!!!!
[right][snapback]461623[/snapback][/right]
[/quote]
In another post, you said you used them before nick?
[color=yellow]dw....the seimens deka kept away from the mototrons on the advice of the yanks (mind you these are the same yanks giving me greif atm)[/color]
Wouldn't you remember if it had MOTOTRON printed on them or not?
[color=yellow]dw....definatly not and don't try twist my words[/color]
at one stage it was his everyday vehicle... do you'd hope it was reliable :)
[color=yellow]dw....who's car? i'm running mine on std injectors as the next objective is tune only best time!!!!![/color]
either way, these ones i have here dont have mototron printed on them, just serial number, and part number according to your post with the different specs.
[color=yellow]dw....good i hope so as stated in the pm's[/color]
i done a quick google before and on many cases i saw people refer to them both as the same.
[color=yellow]dw....i'm led to beleive the quality is very different[/color]
[right][snapback]461631[/snapback][/right]
[/quote]
why are you taking offence at me trying to save you drama's i had agreed to buy some from you remember?
that wont happen now till i can varify the origin as i can't have people coming back to me for warranty if they are not right!!!!
till this thread there was never mention of mototron from you now i wonder?
real good price but your taking the risk your choice!!!!
I'm not taking offence, i'm tring to clear things up, but i only quoted Mototron as i assumed they were the same injector.. ie "Siemens/MotoTron Deka 60lb".. Everywhere i googled suggested they were the same, Hense why i quoted it.
The car is v8capri's, his supercharged V8 GROUP-A, alot of people have seen it at various dyno shootouts, and correction to my original post of 550rwkw, it is 506rwkw.
Eitherway, These are Siemens Deka 60lb babies. Look at my attached picture, no sign of MOTOTRON printed on.. even if the mototron are chinese copies..
Dan.
  • Member For: 20y 17d
Jeezus, talk about trying to put up a smoke screen. Sounds a bit like the 'facts about cooler' thread on the other forum, without any facts :roflmbo:
Technically, they are a Siemens/VDO injector. Excellent injector! Mine have Mototron, and GAS006 stamped on them. Edited by M6 XR6T
  • Member For: 19y 4m 7d
[quote name='Dynowog' date='Nov 3 2006, 11:11 AM']Injector = FI114961
Injector Type = 107961 = Deka IV
Body Type = Long
Distance o-ring to o-ring = 60.4 mm
Static Flow Ibls/hr @ 300 kPA = 63
Static Flow cc/min @ 300 kPa = 660
Coil Resistance (ohm) Impedance = 12 = High
Spray Pattern = 30 degree = Cone
these are the ones i use!!!!
[right][snapback]458857[/snapback][/right]
[/quote]
Are they these ones Dan ?
[quote name='O2STOCK' date='Nov 8 2006, 10:47 PM'][quote name='Dynowog' date='Nov 3 2006, 11:11 AM']Injector = FI114961
Body Type = Long
[/quote]
[right][snapback]461689[/snapback][/right]
[/quote]
yeah, 107961 is printed on the injector
dan
Guest
This topic is now closed to further replies.
