Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 06/11/06 10:46 AM Share Posted 06/11/06 10:46 AM i wasnt running a bov when i fitted my nizpro kit and the turkey gobble was ridiculous..i fitted my vee port and now i get and semi asmatic weeze on occasion,a fooly sick PSSHT sometimes and a goble goble of the same intensity so i really didnt achieve anything..... mind tou i dont think running the vacum signal to the bov off a shared vacum source does it much good....the pod filter onto the turbo is the best noise mod you can do....nothing says "dont phuck with me" like the whistle these things make under boost... Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460697 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 14d Gender: Male Location: OZ Posted 06/11/06 10:50 AM Share Posted 06/11/06 10:50 AM If it gobbles then it aint flowing enough Hiddeous. Its coming back out the filter as well I reckon. Are you using the same vacuum point as std?? Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460698 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 06/11/06 10:58 AM Share Posted 06/11/06 10:58 AM nah i have tried a couple of different vacum points. i think the bov might need a strip down and lube up. Im also going to drill and tap a dedicated vacum supply on the manifold for the BOV. Turbo smart recommended trying that and if that failed going to a slight softer spring from a plumb back bov. The where actually very helpful when i emailed them a querry and got back to me very quickly. Ask Steve how loud the gobble gobble is...he got to hear it up close a couple of times on sat'd night...hehehe Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460703 Share on other sites More sharing options...
Guest newl Guests Posted 06/11/06 11:47 AM Share Posted 06/11/06 11:47 AM Quote Ask Steve how loud the gobble gobble is...he got to hear it up close a couple of times on sat'd night...heheheI think most of us that were there could vouch for how loud it was. Though that being said, mine isn't all that quiet for a stocker either. hehe Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460735 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 30d Gender: Male Location: Perth Posted 06/11/06 11:49 AM Share Posted 06/11/06 11:49 AM Your not wrong there Newl....i was very surprised at how loud yours was.... Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460737 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 5m 30d Gender: Male Location: Perth, WA Posted 06/11/06 12:30 PM Share Posted 06/11/06 12:30 PM IH8TOADS said: If it gobbles then it aint flowing enough Hiddeous. Its coming back out the filter as well I reckon. Are you using the same vacuum point as std??←That's why I run 2 BOV's.The standard plumb back is good for lower boost levels, and almost eliminates the blow back through the turbo, and the V-Port is set fairly tight, so that it only blows off on pretty serious boost levels, so I avoid too much attention from the cops Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460772 Share on other sites More sharing options...
quigebo Member 134 Member For: 19y 1m 2d Location: blue planet Posted 06/11/06 12:34 PM Share Posted 06/11/06 12:34 PM (edited) Goobz said: When you have a turbo doing up to 60-100,000RPM. I highly doubt you will get back spin...RPM will decrease, but it will not back spin.Also afaik the nizpro stage 2 kit runs no BOV is this correct for 390fwkw...Chris ←cha cha cha.. used to get told it was bad in my other turbo car.. does anyone have any real examples of with and without bov turbine failure?I have the nizpro kit and no bov.. doesnt even come with one! with the zf auto you can drive it quiet or loud(not fast obviously!)..like f6 said that massive inlet noise with a big pod just about drowns out everything.. and yeah hiddeous, jump on then off the gas and it scares the crap out of people.. over 20psi trying to escape will do that mines chatters for nearly 15-20 seconds when its on full boost when throttle closes.. Edited 06/11/06 12:37 PM by quigebo Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460775 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 14d Gender: Male Location: OZ Posted 06/11/06 12:45 PM Share Posted 06/11/06 12:45 PM http://www.fordxr6turbo.com/forum/index.ph...pic=24608&st=18this is the little test I did on bugger all boost. My comparison is in there somewhere. Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460785 Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 21y 7m 15d Gender: Not Telling Location: next door.. Posted 06/11/06 12:49 PM Share Posted 06/11/06 12:49 PM sound clips please Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460787 Share on other sites More sharing options...
Evil F6 Donating Members 830 Member For: 19y 5m 13d Gender: Male Location: Sydney Posted 06/11/06 11:20 PM Share Posted 06/11/06 11:20 PM If you want stealth is there any problem with not venting to the atmosphere and plumbing back into the intake? Why do most prefer venting to the atmosphere? I like the sound of some BOV's but why give the cops yet another reason to hassle you! Link to comment https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/page/3/#findComment-460871 Share on other sites More sharing options...
