  • Member For: 19y 3m 16d
Hi All
Heard a nice sounding scoobie on the road the other day. Made a nice whistle sound on the gear change. Don't know much about how these work, do they add performance or are they just for the effect? and are they easy for a diy fit?
Cheers .........muncher
https://www.fordxr6turbo.com/forum/topic/29975-blow-off-valves/
  • Replies 30
  • Member For: 19y 6m 17d
it sounds like a HKS ssq,
these are a jap branded bov.
a bov will give a better response, I little quicker pick up.
but the amount is very hard to even feel. I noticed it between gear changes. but to put it in perspective putting octane booster would feel quicker.
they are just for the noise more then anything, there are heaps on the market but if you are looking to get one, turbo smart make a full kit for the xr6 turbo.
it changes the pipe to a metal on with a bracket for the bov.
this is what I am running.
it is a loud sound, a little too loud for me but everyone has the own thorghts about it.
  • role model
which BOV are you running atm??? also can you get a sound clip please :w00t2:
as im intrested in buying a bov
yeah the car is on the dyno on tuesday, so I can do it then.
at low boost it flutters.(like the vl turbos do)
take into account that I am running around 20psi so it will sound alot louder(more air flowing) then one running say 21psi
  • Member For: 18y 7m 26d
Can I have one of the BOV's that make my car go quicker as well. :w00t2:
So long as the stock one doesn't leak, the only difference an aftermarket one will give is noise.
Knock yourself out:
http://www.935motorsports.com/bovmediaX.htm
  • ASHA - Anti Stooge Hunter Association
  • Member For: 22y 15d
  ypurv4 said:
If you want a loud tut tut tut tut take the standed bov off and block all the holes.
mmmm and look at your turbo blades a couple months later .... you will get back spin, not the best way to get sound. Mate did this, his turbo was gone ... if you run small boost not too muchan issue, but if your running higher boost I wouldnt be doint this
About the initial question, the GFB Stealth FX is a direct replacement also ... fits in the factory position and is adjustable.
  • Member For: 20y 8m 15d
When you have a turbo doing up to 60-100,000RPM. I highly doubt you will get back spin...
RPM will decrease, but it will not back spin.
Also afaik the nizpro stage 2 kit runs no BOV is this correct for 390fwkw...
Chris :pinch:
Chris :spoton:
Good point, never thought of it that way.....re::backspin.
Just a theory I heard a while back when my mates turbo blades went into self destruction. The mechanic at the time blamed it on no release valve and "apparant" back spin.
