turbotom Team Bute Donating Members 1,550 Member For: 21y 7m 23d Gender: Male Location: Adelaide Posted 29/11/06 05:48 AM Share Posted 29/11/06 05:48 AM (edited) 1100 Nm you'd need 400kW at 3500rpm for 1100 Nm ! Edited 29/11/06 05:51 AM by turbotom Link to comment Share on other sites More sharing options...
apache_dj Member 145 Member For: 19y 9m 8d Location: Auckland NZ Posted 29/11/06 07:11 AM Author Share Posted 29/11/06 07:11 AM why? there was a super charged LS1 making only 260RWKW that had just on 1000Nm torque? Link to comment Share on other sites More sharing options...
apache_dj Member 145 Member For: 19y 9m 8d Location: Auckland NZ Posted 29/11/06 07:12 AM Author Share Posted 29/11/06 07:12 AM sorry felahs am loading the drivers for the scanner as I write this so will post the sheet Link to comment Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 8m 16d Location: D SHIRE! Posted 29/11/06 07:12 AM Share Posted 29/11/06 07:12 AM why? there was a super charged LS1 making only 260RWKW that had just on 1000Nm torque?← Link to comment Share on other sites More sharing options...
apache_dj Member 145 Member For: 19y 9m 8d Location: Auckland NZ Posted 29/11/06 07:22 AM Author Share Posted 29/11/06 07:22 AM whats the gag? Link to comment Share on other sites More sharing options...
apache_dj Member 145 Member For: 19y 9m 8d Location: Auckland NZ Posted 29/11/06 08:26 AM Author Share Posted 29/11/06 08:26 AM sorry turns out that just isnt legible lets try this Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 12d Gender: Male Location: Victoria Posted 29/11/06 08:59 AM Share Posted 29/11/06 08:59 AM The dyno is measuring torque at the wheels so it's multiplied by the gear ratio, diff ratio and wheel/tyre size. By the look of the torque curve I'd say it's an auto so the torque converter also will effect the figure. Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 8m 11d Posted 29/11/06 10:52 AM Share Posted 29/11/06 10:52 AM Is that bottom graph you AFR's?If so, you may want to get that checked out. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 9m 18d Gender: Male Location: Sydney NSW Posted 29/11/06 11:03 AM Share Posted 29/11/06 11:03 AM Yeah looks a tad lean, 12.8ish at 5500?? Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 7m 23d Gender: Male Location: Adelaide Posted 29/11/06 12:12 PM Share Posted 29/11/06 12:12 PM whats the gag?←To give you a more realistic approximation of your torque output, you can calculate it with the following formula: Nm = (kW x 9549) / rpmlooking at your graph, I'd estimate your pk torque is about 573 Nm @ 3500 rpm.ie, (210 kW x 9549) / 3500 = 572.94.and your still holding 500Nm at 5500 rpm, so you've got a great constant push in the back right through the rev range.... I gather it's a 4sp auto, as the test was done in 3rd gear.Don't know if you've done any mods to the trans, but your tuner has looked after you by limiting the torque at a sensible level.cheers.tom Link to comment Share on other sites More sharing options...
