  • XR68UZ
  • Member For: 19y 3m 4d
  XR06T said:
  Jaeyon said:
ouch. if I were you I'd claim it under warranty, save yourself the money. if you change the bottom end your warranties void anyway. correct me if im wrong
:nono:
oops did I say something stupid? it might just be me cause im trying to claim everything under warranty :nono:
  • Replies 127
Posted Images
  • Member For: 19y 9m 22d
  Jaeyon said:
  XR06T said:
:nono:
I understand that with so many ppl running more power than this not having any problems you may feel robbed, but I still dont think its fords problem.. its obvious that all cars are made different because of the varied stock power figures we see, so once you push the stock parts further than ford intneded (past stock power) its your problem..
I think if you took that into ford youd have troubles anyway, they told me that they would be able to tell if I'd thrashed my gbox jus by lookin at it!! :nono:
  • Member For: 19y 11m 8d
I chatted to a few people today as im still trying to make up my mind.
atomic motors- 4600+gst and + fitting +a new sump = ~ 7000bucks if nothing else is fooked like valves or head
found a bare long motor, (no turbo, intake plenum, aircon, ps ect ect.) $2800 throw in a set of atomic rods or cappa rods~$1600, install new valve springs$350, 968s which I allready have =4000+ fitting spend the rest on exhaust, intercooler, dump pipe and tuning..
dunno what do you guys think??
  • Member For: 20y 11m 11d
I think something sounds wrong here; only 248kw for a custom tune. A bit on the low side. Is that with the 968's that you have? Did you see your afr's? Were you running 98 ron at the time?
Oh and dont forget to change your handle as it clearly isnt. Sorry - couldnt resist.
yep that's right 248 with 700nm torque, it wasnt with the 968s though I had them at home waiting to go in with an intercooler
EDIT: no I didnt see my afr's, and I allways run 98ron
Edited by built2redline
  • Member For: 19y 2m 9d
If you needed to know what a bf rod and piston looks like, just take a look at the pic's. Its was my number 6 piston and rod.
So my advice do the billet rods and forged pistons now it will be a lot cheaper then later
  • Resident golf buggy drift champion
  • Member For: 19y 5m 25d
So what are the chances of ford fixing a problem like this if all you have is an EDIT and tune?
