F6_Tornado F6+300+ Member 940 Member For: 20y 7m Location: In The Ute Posted 30/10/06 04:51 AM Share Posted 30/10/06 04:51 AM I hope the Master Plumbers Association don’t see this or there goes your ticket Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456690 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 5m 23d Gender: Male Location: Strapped in and holding on Posted 30/10/06 08:28 AM Author Share Posted 30/10/06 08:28 AM Eugene.I welded a fitting on the elbow near the pwr steering ressie, placed a barb and fed the sensor. Easy As for 2.5" to turbo, I'll see. I still have a doughnut and a length of pipe left, and I wouldn't mind re-routing the feed from the comp under the battery tray. 90 deg bend straight off the turbo compressor should get it o fit.. Dano, BOV, running where it was. It will vent/draw some atmospheric, but it's only for a week or so.. Not alot in it.Crossover setup will be changed in roughly a week to a different arrangement.. As for Master Plumbers, well they can GAGF Will be painting it soon.. Boost comes on almost instantly, only requiring 200rpm to get to 8/9 psi... That's from anywhere in the rev range, not just loading it up Compressor surge/chatter is farking loud. Sounds like I have a pair of mating turkeys under my bonnet. Bit ricey for me More pix when painted. Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456794 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 15d Gender: Male Location: Perth Posted 30/10/06 08:57 AM Share Posted 30/10/06 08:57 AM 200rpm for 8/9psi or 2000rpm? wait till you get ride of the crossover and run a manifold that lets you shoot that air straight in... Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456820 Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 3m 30d Gender: Male Location: Perth Posted 30/10/06 09:17 AM Share Posted 30/10/06 09:17 AM F6_Tornado said: I hope the Master Plumbers Association don’t see this or there goes your ticket ←rofl Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456844 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 5m 23d Gender: Male Location: Strapped in and holding on Posted 30/10/06 09:54 AM Author Share Posted 30/10/06 09:54 AM hiddeous said: 200rpm for 8/9psi or 2000rpm? wait till you get ride of the crossover and run a manifold that lets you shoot that air straight in... ←From any give rpm point. It takes 200rpm to be at fullboost. ( 9psi atmo )Comprende' ????? Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456866 Share on other sites More sharing options...
Guest newl Guests Posted 30/10/06 11:21 AM Share Posted 30/10/06 11:21 AM Quote Sounds like I have a pair of mating turkeys under my bonnet. I almost lost my coffee! Thanks for that one Ben. Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-456936 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 5m 23d Gender: Male Location: Strapped in and holding on Posted 06/11/06 12:39 PM Author Share Posted 06/11/06 12:39 PM OK.I'll try and post up some pix of the (semi) finished pipework tomorrow, painted black.To quote F6_Tornado" Ohhh farkk. That looks faaarking terrible.. Ohhh for faaaark sakes, that's faaarkin horrid. That's no good at all, nup, that's F*&*KED " Meh, he's a \|/ and it's MY temporary pipework, not his.. ( I'm not too keen on it either ) ( did I mention he's feverishly running around finding an intercooler, coz now he's scared I'm quicker than him) LMAO old boy.. Anyhoo, Results:Well, the thing runs cool. about 10-15 deg above ambient, and that's with me leaning on the throttle.Put into perspective, it runs at around 32-38 degrees during the day, flogging it around. That's colder than the F6 cooler ran at night, on cruise down the fwy.. Impressive.Lag, well the tune isn't 100% so I can't judge fully, but seems a touch lagier, but it might be the volume of air has increased with the 4" turbo inlet/intercooler piping, so it's more progressive, and less snappy, but still punching the numbers?? I'm also running 5psi less boost- which might have some say in it.. I'll be getting onto the dyno tomorrow to do a few or four tunes and see what happens. I'll be posting up dyno sheets tomorrow night with some pix if I get the chance.... Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-460780 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 21y 11d Location: Mildura Posted 06/11/06 12:50 PM Share Posted 06/11/06 12:50 PM Dannopower said: Looks great mate, and a great write up as well.Just wondering a couple of things,-Where abouts are you going to mount the blow off valve, and plumb it back into, now your not using the rear of the stock plenum?-Is there enough room to run the intake pipe over the top and around the back of the intake manifold and have it entering the throttle body as a bend (similar to the N/A intake pipe setup?) I thoight this might keep any pipes from being exposed to the top of the exhaust manifold?Great job anyway! ←You can fit a 3" pipe by entering it the same way as the N/A intake. I've been running one for some time now. Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-460788 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m Gender: Male Location: OZ Posted 06/11/06 12:52 PM Share Posted 06/11/06 12:52 PM haaa gramps comment is classic. Hopefully the weather holds up on Wed cos I bet your mad keen to test the apple on the track. Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-460789 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 5m 23d Gender: Male Location: Strapped in and holding on Posted 06/11/06 12:53 PM Author Share Posted 06/11/06 12:53 PM macka said: You can fit a 3" pipe by entering it the same way as the N/A intake. I've been running one for some time now. ←That's archaic Macka.... Wait till you see what we ( gramps- I pinched it ) have got planned.. Link to comment https://www.fordxr6turbo.com/forum/topic/29699-my-intercooler-install/page/4/#findComment-460791 Share on other sites More sharing options...
