Guest Guests Posted 26/10/06 03:00 PM Share Posted 26/10/06 03:00 PM Hi all,I just bought Youngy's old Xtreme clutch and had it fitted today by Ford. Feels realy solid compared to the stock unit but it has an awful shudder when taking off from a dead stop. I know the clutch is ok because I went for a drive in the previous car it was in before it was taken out. Could it of been put in wrong? Maybe not tightened properly?Any help would be greatly appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/ Share on other sites More sharing options...
Guest Guests Posted 26/10/06 03:05 PM Share Posted 26/10/06 03:05 PM 03XR6T said: Hi all,I just bought Youngy's old Xtreme clutch and had it fitted today by Ford. Feels realy solid compared to the stock unit but it has an awful shudder when taking off from a dead stop. I know the clutch is ok because I went for a drive in the previous car it was in before it was taken out. Could it of been put in wrong? Maybe not tightened properly?Any help would be greatly appreciated. ←more info on the parts used please! Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454967 Share on other sites More sharing options...
Guest Guests Posted 26/10/06 03:15 PM Share Posted 26/10/06 03:15 PM It's a xtreme 10.5in ceramic ultra heavy duty single plate clutch and billet chrome moly fly wheel to suit, and I have the dreaded T5 Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454975 Share on other sites More sharing options...
Guest Guests Posted 26/10/06 03:24 PM Share Posted 26/10/06 03:24 PM I am asuming you removed it and fitted the components in as they were or did you machine the flywheel?if so (the latter) you now have a mismatch in surfaces causing the shudder put up with it it should settle or time for a newy!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454982 Share on other sites More sharing options...
Guest Guests Posted 26/10/06 03:28 PM Share Posted 26/10/06 03:28 PM Na wasn't machined. Just pulled out of previous car last night and fitted into mine today.Will I need a whole new unit or can it be fixed? Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454984 Share on other sites More sharing options...
Guest Guests Posted 26/10/06 03:40 PM Share Posted 26/10/06 03:40 PM 03XR6T said: Na wasn't machined. Just pulled out of previous car last night and fitted into mine today.Will I need a whole new unit or can it be fixed?←call me 0405 400 572 Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454986 Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 4m 10d Gender: Male Location: Perth Posted 26/10/06 03:46 PM Share Posted 26/10/06 03:46 PM 03XR6T said: Na wasn't machined. Just pulled out of previous car last night and fitted into mine today.Will I need a whole new unit or can it be fixed?←Mate Titans rang me and I said for them to just get it looked at by brake and clutch to make sure all was sweet, The do shudder a little but once you get used to driving around them that will change and you will find the way to drive it without shudder. Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-454987 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 11m 29d Location: Canberra Posted 26/10/06 10:43 PM Share Posted 26/10/06 10:43 PM My clutch shudders too mate, and Mal Woods said it shouldn't... I re-bled it and it helped heaps still has a slight shudder, but most of the time its only minor, occasionally I get a massive one where it feels like the diff is gonna drop to the ground I've put it down to incorrect installation, or they didn't machine the flywheel before hand. By the way, Mal didn't do the install, it was done here in canberra... depending on how the gearbox goes, I'll get it re installed after christmas and see how it goes then. Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-455049 Share on other sites More sharing options...
Guest Guests Posted 27/10/06 01:57 AM Share Posted 27/10/06 01:57 AM Xtreme F6 said: Mate Titans rang me and I said for them to just get it looked at by brake and clutch to make sure all was sweet, The do shudder a little but once you get used to driving around them that will change and you will find the way to drive it without shudder.←Ok thanks heaps Simon. I'll give them a call. Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-455136 Share on other sites More sharing options...
Guest Guests Posted 27/10/06 02:04 AM Share Posted 27/10/06 02:04 AM JimmyXR6T04 said: My clutch shudders too mate, and Mal Woods said it shouldn't... I re-bled it and it helped heaps still has a slight shudder, but most of the time its only minor, occasionally I get a massive one where it feels like the diff is gonna drop to the ground ←Mine is a massive shudder all the time, not just occasionally. I might re bleed it if Ford say they can't do anything.Cheers for the help mate By the way, I can't get any photos of my mags to upload. Any helpful ideas? Link to comment https://www.fordxr6turbo.com/forum/topic/29623-clutch-shudder/#findComment-455140 Share on other sites More sharing options...
