NeedmorePower Member 192 Member For: 19y 2m Posted 25/10/06 01:12 AM Author Share Posted 25/10/06 01:12 AM looks very nice but the price tag is even nicer I thought the nizpros plenum was almost the most expensive but again I was wrong Link to comment Share on other sites More sharing options...
NeedmorePower Member 192 Member For: 19y 2m Posted 25/10/06 06:01 AM Author Share Posted 25/10/06 06:01 AM I sent the guy a email about his plenum and this is what they saidlol, no your not being a smart arse. I appreciate it. There's a huge different between our plenum and Nizpros. Theres is cast, our is billet and pressed alluminium. The heat transfer for cast is terrible. Heats up way too much...and ours isnt made in a mold. They're engineered on CAD programes Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 13d Gender: Male Location: Strapped in and holding on Posted 25/10/06 06:15 AM Share Posted 25/10/06 06:15 AM I sent the guy a email about his plenum and this is what they saidlol, no your not being a smart arse. I appreciate it. There's a huge different between our plenum and Nizpros. Theres is cast, our is billet and pressed alluminium. The heat transfer for cast is terrible. Heats up way too much...and ours isnt made in a mold. They're engineered on CAD programes←Wow, so they must be good..Sounds like a hi-tech answer, bag the opposition. Please explain " the heat transfer for cast is terrible " Link to comment Share on other sites More sharing options...
Goldbullet Member 883 Member For: 19y 10m 4d Location: Frankston Posted 25/10/06 06:19 AM Share Posted 25/10/06 06:19 AM (edited) LOOKS VERY MUCH LIKE A NITTO←Like I said I have one and it is a Nitto Edited 25/10/06 06:20 AM by Goldbullet Link to comment Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 2m 20d Location: In The Ute Posted 25/10/06 06:28 AM Share Posted 25/10/06 06:28 AM I sent the guy a email about his plenum and this is what they saidlol, no your not being a smart arse. I appreciate it. There's a huge different between our plenum and Nizpros. Theres is cast, our is billet and pressed alluminium. The heat transfer for cast is terrible. Heats up way too much...and ours isnt made in a mold. They're engineered on CAD programes←Wow, so they must be good..Sounds like a hi-tech answer, bag the opposition. Please explain " the heat transfer for cast is terrible "←The heat transfer will be proportional to the composition of the cast. Namely what metals it consists of and then comparable to the material used in the said Plenum.If it’s fabricated from off the shelf material you will be able to calculate its heat transfer properties, however getting the composition of the cast will be impossible without some destructive testing, unless the manufacturer is willing to supply it? HahahahhaSo its one of those things!!! How long is a piece of string?Secondly is it even worth worrying about as the time frame that the air spends in it is negligible. From a technical and engineering point of view its better, but from a performance point of view again it would be negligible!!!Consider the air temp internal and external at any given time and is it better or worse? Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 2d Gender: Male Location: Victoria Posted 25/10/06 06:33 AM Share Posted 25/10/06 06:33 AM I sent the guy a email about his plenum and this is what they saidlol, no your not being a smart arse. I appreciate it. There's a huge different between our plenum and Nizpros. Theres is cast, our is billet and pressed alluminium. The heat transfer for cast is terrible. Heats up way too much...and ours isnt made in a mold. They're engineered on CAD programes←Wow, so they must be good..Sounds like a hi-tech answer, bag the opposition. Please explain " the heat transfer for cast is terrible "←They bagged the opposition is their advertisment email tthey sent to all tuners aswell. I've seen one of these used on a 6cyl N/A Falcon and it made less power than the stock unit. Apparently the runners are to short and it's ideal RPM range is 7500rpm they discovered from this test, which is to high for a Falcon 6. Link to comment Share on other sites More sharing options...
2fardown Member 526 Member For: 19y 8m 16d Gender: Male Location: Brisbane Posted 26/10/06 03:42 AM Share Posted 26/10/06 03:42 AM I sent the guy a email about his plenum and this is what they saidlol, no your not being a smart arse. I appreciate it. There's a huge different between our plenum and Nizpros. Theres is cast, our is billet and pressed alluminium. The heat transfer for cast is terrible. Heats up way too much...and ours isnt made in a mold. They're engineered on CAD programes←Wow, so they must be good..Sounds like a hi-tech answer, bag the opposition. Please explain " the heat transfer for cast is terrible "←They bagged the opposition is their advertisment email tthey sent to all tuners aswell. I've seen one of these used on a 6cyl N/A Falcon and it made less power than the stock unit. Apparently the runners are to short and it's ideal RPM range is 7500rpm they discovered from this test, which is to high for a Falcon 6.←Why you would put such a plenum on an N/A is beyond me.... Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 13d Gender: Male Location: Strapped in and holding on Posted 26/10/06 07:25 AM Share Posted 26/10/06 07:25 AM Why you would put such a plenum on an N/A is beyond me....←Simon has answered this in my thread "Plenum Theorum" Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 5m 4d Gender: Male Location: Perth, WA Posted 26/10/06 07:39 AM Share Posted 26/10/06 07:39 AM So that plenum design incorporates the runners aswell? So they are basically very short runners yeah?And excuse my ignorance but what does billet mean? Link to comment Share on other sites More sharing options...
Lumpen Poison Fish. Poison Fish. TASTY FISH!!! Donating Members 5,181 Member For: 21y 10m 13d Gender: Male Location: The Bogan Shire Posted 26/10/06 09:10 AM Share Posted 26/10/06 09:10 AM And excuse my ignorance but what does billet mean?←A billet is a single piece of solid metal, typically cast like an ingot but can be very large or small.There are two types of billet items:Genuine Billet: Item's actually machined or forged down from a single piece of metal.The Hot-Rodders (wank) Billet: Items that are typically cast from numerous billet's melted down. Items such as billet mirrors, steering wheels and lots of other bling fall into the catergory.Lumpy Link to comment Share on other sites More sharing options...
