hsv eater Member 21 Member For: 18y 11m 19d Posted 17/10/06 11:51 AM Share Posted 17/10/06 11:51 AM hi everyone,just wondering,im about to get the atomic bottom end with atomic cams and valve springs,bosch 5 bar fuel pump.what size injectors do I need to get. I am aiming for about 380-400rwkw.mine is a bf f6 tornado zf 6 speed.also with that amont of power will the diff and rear axels handle that much power and torque? thanks everyone, looking forward to replies. Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/ Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 4m 29d Gender: Male Location: SoR, WA Posted 17/10/06 12:01 PM Share Posted 17/10/06 12:01 PM hsv eater said: hi everyone,just wondering,im about to get the atomic bottom end with atomic cams and valve springs,bosch 5 bar fuel pump.what size injectors do I need to get. I am aiming for about 380-400rwkw.mine is a bf f6 tornado zf 6 speed.also with that amont of power will the diff and rear axels handle that much power and torque? thanks everyone, looking forward to replies.←The big question is will the ZF hold up (looks like your the test pilot).There are people here with numbers like that with standard diffs just dont go hooking up those tyres with that much power otherwise *bang*. there goes the CVs. Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-450643 Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 6m 21d Location: Sutherland Shire, Sydney Posted 17/10/06 08:13 PM Share Posted 17/10/06 08:13 PM Adrian6T said: hsv eater said: bf f6 tornado ←*bang*. there goes the CVs.←Its a Tornado(ute), therefor no CV's.Not to sure about the utes. Mine copped 255rwkw with no drama's, but that's a long way from your power level.F6 Utes seems to be holding up to the repeated caning he gives it with over 300rwkw...Chris Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-450744 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 17d Gender: Male Location: Strapped in and holding on Posted 18/10/06 12:33 AM Share Posted 18/10/06 12:33 AM Just a quick question.Firstly, why is Mal Wood trying to solve this for you?? lol. OK, Simon - Extreme has a customer running near 400rwkw in an A F6 BF. F6 Tornado is running 330rwkw, A6 F6 Tornado.Neither have issues, except for flex plate, but that was a Ford issue. ( Bolts not done up ) Both are stock bottom ends. I reckon save your cash if you going 380rwkw. I'll be up there shortly. ( about 360rwkw )Wog has a couple of utes tuned, running stock bottom ends ( XR's ) and pumping 360rwkw and running low 11's.. I have no diff issues, it's a bit creaky, but might need a general tighten up, but I've done 60,oookm too.. Mine is a manual, and that has it's own noise issues. I can step off the cutch at 4500rpm on MT's and everything is fine..One word of warning, when you up the power in a ute, the back end (suspension) will twist on you. I've nearly been speared off the road with coil bind, ( I think it's called that ) where I hit 3rd gear and the thing just steers the back end.. Scary stuff.. Some better springs, shocks or tramp rods etc will help that though. ( Mine still stock ) I did have the hardcover off, and that didn't help the cause. Bit more weight with the hardcover seems to help too.As far as injector choice, Nizpro 100's or Siemens. ( wog sells Siemens ) Who are you going with for intercooler/plenum? Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-450778 Share on other sites More sharing options...
hsv eater Member 21 Member For: 18y 11m 19d Posted 18/10/06 10:13 AM Author Share Posted 18/10/06 10:13 AM F6 UTE said: Just a quick question.Firstly, why is Mal Wood trying to solve this for you?? lol. OK, Simon - Extreme has a customer running near 400rwkw in an A F6 BF. F6 Tornado is running 330rwkw, A6 F6 Tornado.Neither have issues, except for flex plate, but that was a Ford issue. ( Bolts not done up ) Both are stock bottom ends. I reckon save your cash if you going 380rwkw. I'll be up there shortly. ( about 360rwkw )Wog has a couple of utes tuned, running stock bottom ends ( XR's ) and pumping 360rwkw and running low 11's.. I have no diff issues, it's a bit creaky, but might need a general tighten up, but I've done 60,oookm too.. Mine is a manual, and that has it's own noise issues. I can step off the cutch at 4500rpm on MT's and everything is fine..One word of warning, when you up the power in a ute, the back end (suspension) will twist on you. I've nearly been speared off the road with coil bind, ( I think it's called that ) where I hit 3rd gear and the thing just steers the back end.. Scary stuff.. Some better springs, shocks or tramp rods etc will help that though. ( Mine still stock ) I did have the hardcover off, and that didn't help the cause. Bit more weight with the hardcover seems to help too.As far as injector choice, Nizpro 100's or Siemens. ( wog sells Siemens ) Who are you going with for intercooler/plenum?←thanks for that info f6 ute. I currently have the hybrid I/c with plazmaman plumbing.do you think the bottom end will handle 360-380rwkw? cause my tuner/installer told me im nearly on the edge with my current power,so that's why I wanted to put a new bottom end. I have 320rwkw at the moment with the above plus 42pound drilled injectors,powerstat,k&n,3.5"dump,3.5"metal cat,and remus cat back system,ultra shocks f&r, with custom tune running 17pounds down low and tapering down to 12pounds. Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-451014 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 24d Location: In The Ute Posted 18/10/06 10:43 AM Share Posted 18/10/06 10:43 AM One or two Metal cat cats?Once you go over 300rwks!! one just aint going to make the grade and if you try and push too much flow accross it it wont last long as all.I dont think the bottem end is a problem at all and ive seen one that was @ 400rwks after it was pulled down and it was like brand new after 20,000 km. Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-451041 Share on other sites More sharing options...
hsv eater Member 21 Member For: 18y 11m 19d Posted 19/10/06 08:52 AM Author Share Posted 19/10/06 08:52 AM F6_Tornado said: One or two Metal cat cats?Once you go over 300rwks!! one just aint going to make the grade and if you try and push too much flow accross it it wont last long as all.I dont think the bottem end is a problem at all and ive seen one that was @ 400rwks after it was pulled down and it was like brand new after 20,000 km. ←can you explain how to set up the exhaust with twin cats? Link to comment https://www.fordxr6turbo.com/forum/topic/29368-injectors/#findComment-451464 Share on other sites More sharing options...
