937 Member 266 Member For: 18y 9m 9d Posted 17/10/06 10:27 PM Author Share Posted 17/10/06 10:27 PM What adaptors did you guys use to fit between the block and oil filter. I was think about the Universal Engine Oil Cooler Kit form perma-cool but I am not to sure if the adaptor fits and it also use's clamps on the fitting. Would hate for one to blow off. Any more details on the rest of the setup that you guys are runningThanks←Also make sure that the Adaptor got a Thermostat build in.Speco makes one. Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-450754 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 2m 5d Gender: Male Location: The Shire Sydney AUS Posted 19/10/06 07:40 AM Share Posted 19/10/06 07:40 AM Just A quick Pic of the one I Installed... P.S, there is no such thing as a thermostat controlled adaptor plate, the 1 pictured above has a pressure release valve on which is rated at 250 kpa... you would want the plumbing to match to ensure saftey.... Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451433 Share on other sites More sharing options...
937 Member 266 Member For: 18y 9m 9d Posted 19/10/06 07:53 AM Author Share Posted 19/10/06 07:53 AM Just A quick Pic of the one I Installed... P.S, there is no such thing as a thermostat controlled adaptor plate, the 1 pictured above has a pressure release valve on which is rated at 250 kpa... you would want the plumbing to match to ensure saftey.... ← I did order an Adaptor from Auto Barn,and was there when he rang Speco.And yes I was told it's got a Thermostat build in.See picturehttp://www.speco.com.au/acccoolers.html#sandwich Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451438 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 2m 5d Gender: Male Location: The Shire Sydney AUS Posted 19/10/06 08:01 AM Share Posted 19/10/06 08:01 AM Just A quick Pic of the one I Installed... P.S, there is no such thing as a thermostat controlled adaptor plate, the 1 pictured above has a pressure release valve on which is rated at 250 kpa... you would want the plumbing to match to ensure saftey.... ← I did order an Adaptor from Auto Barn,and was there when he rang Speco.And yes I was told it's got a Thermostat build in.See picturehttp://www.speco.com.au/acccoolers.html#sandwich←My Instuction Leaflet say's that it is a pressure control valve... and when I quizzed rare spares in syd about it , they said the same... its only a spring and ball bearing in there so I dont see how that would regulate flow via temp..anyway good luck with it... You can get the oil cooler off Ebay for about $40.... Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451441 Share on other sites More sharing options...
937 Member 266 Member For: 18y 9m 9d Posted 19/10/06 08:07 AM Author Share Posted 19/10/06 08:07 AM (edited) Got the Cooler unit. And as soon as I get the adaptor I go back to the Filter Factory and get the hoses and the rest of the fittings.Thank you for the pictures.Ps, what is your oil temp running @ with the cooler. Edited 19/10/06 08:09 AM by 937 Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451444 Share on other sites More sharing options...
vincexr6t Member 31 Member For: 19y 2m 8d Location: Adelaide Posted 19/10/06 08:46 AM Share Posted 19/10/06 08:46 AM How many people run a Thermostat on the oil cooler line. I know that you do it to help the motor /oil get up to the correct temp quicker but surly with the turbo the oil will heat up a lot quicker and higher then a non turbo.So do you have to have in the T or is it fine with out one.???? Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451462 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 2m 5d Gender: Male Location: The Shire Sydney AUS Posted 19/10/06 11:13 AM Share Posted 19/10/06 11:13 AM Got the Cooler unit. And as soon as I get the adaptor I go back to the Filter Factory and get the hoses and the rest of the fittings.Thank you for the pictures.Ps, what is your oil temp running @ with the cooler.←bout 80c when driving normal, when caining it about 90-100..pete Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451545 Share on other sites More sharing options...
937 Member 266 Member For: 18y 9m 9d Posted 19/10/06 09:28 PM Author Share Posted 19/10/06 09:28 PM Got the Cooler unit. And as soon as I get the adaptor I go back to the Filter Factory and get the hoses and the rest of the fittings.Thank you for the pictures.Ps, what is your oil temp running @ with the cooler.←bout 80c when driving normal, when caining it about 90-100..pete←Thank you for that info.@ the moment my oil temp goes to 100 C after about 20 km and stays there.The cooler should bring it down . Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451639 Share on other sites More sharing options...
937 Member 266 Member For: 18y 9m 9d Posted 20/10/06 07:40 AM Author Share Posted 20/10/06 07:40 AM (edited) Just got my Oil Cooler Adaptor with build in Bimetal Thermostat.See Picture. Edited 20/10/06 07:48 AM by 937 Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-451884 Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 19y 2m 2d Gender: Male Location: Sydney Posted 22/10/06 10:53 PM Share Posted 22/10/06 10:53 PM Tell us the price, son! Link to comment https://www.fordxr6turbo.com/forum/topic/29347-oil-cooler/page/2/#findComment-452802 Share on other sites More sharing options...
