  • Member For: 19y 10m 29d
Thought I would call upon you guys for some answers.
How much difference is there in engine components in an N/A engine as to a XR6T engine.
In my understanding, the following things could be used in both engines, or used to build an XR6T engine. Feel free to add to this or correct me if im wrong-
-Block,
-Sump (maybe needs a oil pickup for the turbo??)
-Crank
-Head Itself (perhaps valve guides and seats are a little different for the t??)
-Complete VCT setup (gears etc)
-Cams and cam cradles (Perhaps the T has different camshafts??)
-Rocker Cover
-Lower intake manifold
-Sensors (crank angle sensors etc)
-Oil Pump
Is there anything else, feel free to add more or correct me if im wrong.
https://www.fordxr6turbo.com/forum/topic/29265-na-ba-engine-components/
  • Member For: 22y 9d
-Block,
-Crank
-Rocker Cover
-Oil Pump
Block is the same
Sump has a hole for the oil return line
Crank is the same
Only the valves and valve seats are the same
VCT setup is the same hardware just different ECU tune
Cams are the same
Rocer cover is only different color
Lower intake only has butterflys removed
Sensors are the same
Oil pumo is the same but the windage tray has a baffle on it.
  • Moar Powar Babeh
  • Member For: 19y 7m 12d
  Venom XR6 said:
  Dannopower said:
Thought i would call upon you guys for some answers.
-Block,
-Crank
-Rocker Cover
-Oil Pump
Block is the same
Crank is the same
Cams are the same
Dont xrt's have inconel exhaust valves?
  • Member For: 22y 4m 12d
-Block,
-Crank
-Rocker Cover
-Oil Pump
Block is the same
Crank is the same
Cams are the same
Yes, and they are damned expensive as well :stirthepot:
  • 3 weeks later...
-Block,
-Crank
-Rocker Cover
-Oil Pump
Block is the same
Crank is the same
Cams are the same
I meant to say the valves and valve seats are the only difference. Stuffed that up.
  NOS XR said:
  Quote
Why are the butterflys removed in a Turbo?
Nizpro are said to remove the butterflys when they fit their Nizpro upper intake to a N/A donk.
Because they simply aren't needed, as the boost does the job of increasing low down torque that the butterflies do in the NA engines. It also saves a few dollars and might slightly increase airflow. No need for them in a turbo engine really.
