Blow Off Valve Installed!
CJF077
Guest StevoD
  • Guests
  ninka said:
Why would you fit bits to your car if they don't make it either look better or go faster? :thumbsup:
I'm no expert on this stuff, but I have just added a couple of thoughts...
The BOV may help with the life of your turbo - reduced shock to bearings etc. due to compressor surge when changing gears.
Also it should help maintain turbo pressure through gear changes by keeping the turbo spooling giving you increased torque at low rpm.
An after market BOV should deliver less turbo lag and inprove the life of your turbo.
  • Replies 105
Posted Images
  • Member For: 22y 2m 9d
Sure it would if the capacity is greater than the factory fitted BOV, and that capacity is actually needed!
I don't think the pressure rise is an issue with factory boost level at only 5-6 psi, but once you start increasing boost beyond 10-12 psi, then the volumetric capacity of the factory fitted BOV unit will probably struggle. I don't have exact information on the capacity of the factory BOV, so please don't take my guess as exact science!! :thumbsup:
  • The Noble Leader
  • Administrator
  • Member For: 22y 4m 21d
  Mommers said:
Hey Chris,
Do you still get the same effect even though you car is an auto, and can u hear it inside the car.
Yes you can hear it in the car.. quite loud too.. :D
  • The Noble Leader
  • Administrator
  Cro said:
Chris revs to 2000 on purpose just so he can hear the thing go...
I must admit I like it :)
haha its a habit :lol:
  • 11 months later...
Guest Basher_tsv
  • Guests
Just a quick one on this ...
I have the same GFB BOV installed and it is great but must admit the snug fit makes it a hassle to adjust (From ON to OFF) and I just couldn't be bothered - but the reason I went the Stealth in the first place (apart from the great quality) was so I could adjust it and turn it off when I wanted.
I have seen a pic on here with the BOV installed on the large black pipes coming up over the block from the turbo (technical I know - but hey that is what they are to me) and just cut in with clamps either side.
I also believe there is no problem installing the BOV here and just blocking off where the factory one goes.
This would make accessing the valve so much easier - does it affect anything if it goes here ? Anyone ??
Thanks!
B.
  • Member For: 21y 16d
While we're on the topic of aftermarket BOV's, I'm curious to know how they affect vehicle warranty should you leave it in when having it serviced...
(Correct, I have no idea when it comes to this stuff)..
Guest Basher_tsv
  • Guests
They have zero impact on warranty.
Mine has been in 3 times (last was the 15k service) and there is not mention or problem with the dealer.
B
  • Complete Bastard
  • Member For: 21y 3m 1d
Came to a bit of grief today fitting the Stealth FX BOV as described in CJ's post above. All was going well until I removed the old BOV and found that the fittings on the Stealth FX were nothing like the Bosch part.
Picked up the Stealth FX from MRT at Ryde and they have a fantastic range of go fast bits for rally cars and Rex but the XR6T is obvioulsy a little unknown to them. They had no idea that the universal Stealth FX does not fit the XR6T unless you have the specific fittings (which do not come in the standard kit).
The lesson here, make sure you get the correct fittings for BOV. Both the high pressure entry port and the plumb back exit port need to have a 25mm barbed fitting to suit the rubber hose on the XR6T. The universal BOV by default has a 30mm barbed fitting for the plumb back exit port and about a 50mm straight fitting on the HP side. The 30mm fitting can be screwed out and a 25mm one fitted and the base gets an 25mm barbed insert fitted and held with a grub screw.
A quick trip to GFB at Marrickville solved my problems as MRT did not carry any stock of the adaptors.
I have it fitted now and damn it is a tight squeeze!
