jt Member 126 Member For: 20y 7m 19d Location: Geelong, Vic Posted 04/06/04 12:19 PM Share Posted 04/06/04 12:19 PM Thanks xr6ism but I'm in Geelong, Vic. Link to comment Share on other sites More sharing options...
XR6ISM ASHA - Anti Stooge Hunter Association Member 535 Member For: 21y 7m 9d Location: Sydney Bronx :) Posted 06/06/04 03:42 AM Share Posted 06/06/04 03:42 AM Ah bummer, not to worry, ill see if I can somehow record the noise for you Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 2m 12d Location: Mount Isa Queensland Go the Maroons Posted 06/06/04 01:08 PM Share Posted 06/06/04 01:08 PM If you've got it to the air are you putting a filter on it?Got this response from GFB this morning..Hi Chris,I assume he was concerned about unfiltered air entering the engine? If so, aBOV is like a one-way device, there is no possible condition in which airwould actually go IN through the valve. Besides which, if you put a filteron it (some rally guys will to prevent dirt from getting into the movingparts) it kills the noise off completely, in which case you might as wellstick with the plumb back! Rest assured, if it needed a filter, we would fitone.Cheers,Brett TurnerEngineer/Technical SalesGo Fast Bits+612 9569 7648www.gofastbits.com.au This is not entirely true unless GFB have changed the spring pressures on their blow off valves. If the Blow off valves spring resistance against compression is not great enough at idle the Vacuum produced by the intake can overcome the pressure of the spring and force open the piston allowing air to enter the exhaust of the blow off valve. most blow off valves have adjustments as does my GFB Mach 1 to adjust the spring to stop the valve from opening at idle but still allow it to be responsive on decel. I think this is important if you are looking for peak performace as all engines are different. That said GFB is an excellent product. Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 2m 12d Location: Mount Isa Queensland Go the Maroons Posted 06/06/04 01:12 PM Share Posted 06/06/04 01:12 PM Does this increase performance?? or is the fancy woosh sound the only advantage If you intend on greater inlet pressures an aftermarket or upgraded bosch unit off a porsche turbo would be the go because at higher boost pressures the blow off valve can leak. Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 2m 12d Location: Mount Isa Queensland Go the Maroons Posted 06/06/04 01:20 PM Share Posted 06/06/04 01:20 PM stick to the topic mate....You know jack all about this don't you. First time Ford Australia has touched a turbo, we can't expect you to know too much. Say something interesting and not just refer to V8's on a turbo website!!!!!So last year was the first time that ford won a championbship for how many years....since allan moffat, sorry I can't remember.Finally Ford has a chance since they downgraded the Late model camira aerodynamics for the last 4 years to make the championship more 'exiting"! What's exciting about a ford winning? The fact that you1- I'm not you're mate. 2) I know plenty about this. 3) It's not the first time Ford Australia has touched a turbo. 4) Holden's losing is interesting. 5) Late model camira dynamics are just an Opel ripoff anyway. 6) STOP USING OUR DIFFS!!!!!!!! 7) Finish your sentences. I saw you and my smart-a$$ detector went off. If you're gunna hang smart remarks as a first post, your best bet is to not pick on the owner of this website. And stop using our toploader gearboxes. Mates building a VK with a stroker engine guess what ford nine inch. Mates VH SS ford toploader and Ford nine inch. Link to comment Share on other sites More sharing options...
SR-71 Blackbird Member 235 Member For: 21y 2m 12d Location: Mount Isa Queensland Go the Maroons Posted 06/06/04 01:26 PM Share Posted 06/06/04 01:26 PM A few guys have tried these on the Jap turbo cars... the main plus about hte model of BOV obviously is the ability to control its plumback/atmospheric venting capabilites. This SHOULD fix the common backfrie problem found when replacing a sotck plymback item for a atmospheirc vetning BOV correct? Wrong... after checking out a few of them fitted out on some fairly modified cars, we came to the conclusion that they weren't as good as the manufacturer states... there is still a backfire issue, casuing richness and puff's of black smoke on gearshift despite having the BOV set to about 40-60 which should allow enough air to bypass back into the intake system adn counterweight the fuel being dumped regardless. Very good concept I must admit, but not 100% satisfied with results yet. Pretty much teh same as any aftermarket BOV, which means a tune is needed to fix the richness on shift to compensate for the atmostpheric vent. Good to hear though its working for you. The backfires and flames from added fuel is only evident with cars fitted with vane air flow meters the T had a map sensor so doesn't suffer from this problem. Link to comment Share on other sites More sharing options...
jt Member 126 Member For: 20y 7m 19d Location: Geelong, Vic Posted 20/06/04 09:28 AM Share Posted 20/06/04 09:28 AM :cartman: I'm still considering getting one. Do I need any special adaptors or fittings?Or does it all come with everything you need? Link to comment Share on other sites More sharing options...
God666 Complete Bastard Donating Members 1,123 Member For: 21y 1m 17d Gender: Male Location: Sydney Posted 20/06/04 09:34 AM Share Posted 20/06/04 09:34 AM It fits straight on if they supply you with the correct fittings.The lesson here, make sure you get the correct fittings for BOV. Both the high pressure entry port and the plumb back exit port need to have a 25mm barbed fitting to suit the rubber hose on the XR6T. The universal BOV by default has a 30mm barbed fitting for the plumb back exit port and about a 50mm straight fitting on the HP side. The 30mm fitting can be screwed out and a 25mm one fitted and the base gets an 25mm barbed insert fitted and held with a grub screw.I originally came to grief as the supplier (MRT) was unfamiliar with the BA fittings. In essence, the inlet and outlet need to be 25mm barbed fittings. That is all.It is a tight fit to get it in and it makes it easier if you get a longer 4mm vacuum hose (I think it is 4mm). The one that is on the car is just a little short.Cheers,Gary Link to comment Share on other sites More sharing options...
jt Member 126 Member For: 20y 7m 19d Location: Geelong, Vic Posted 21/06/04 11:05 AM Share Posted 21/06/04 11:05 AM If I was to get one should I get it sent from the supplier ( GFB ) or should I just ask from where you can get them from, such as autobarn? I dont know whether they would have the fittings there? Or can you get the fittings from somewhere else? Link to comment Share on other sites More sharing options...
God666 Complete Bastard Donating Members 1,123 Member For: 21y 1m 17d Gender: Male Location: Sydney Posted 21/06/04 12:46 PM Share Posted 21/06/04 12:46 PM jtIf I was to get one should I get it sent from the supplier ( GFB ) or should I just ask from where you can get them from, such as autobarn?Six choices in Victoria:Australian Auto Accessories17 Moncrief RdNunawading, VIC 3131Ph: (03) 9878 4700Autobarn Mildura Cnr 15th St & Etiwanda AveMildura VIC 3500Ph: (03) 5023 8888 Autobarn Swan Hill 40 Campbell StSwan Hill VIC 3586Ph: (03) 5033 1175Revolution Race Gear9 Doveton Street North Ballarat VIC 3350 Ph: 03 5332 9888TTZ Performance300ZX and Nissan specialists245 Bulleen RdBulleen VIC 3105Ph: 03 9842 7699URD Automotive3/6 Woodbine CourtWantirna South, VIC 3152 Link to comment Share on other sites More sharing options...
