Guest newl Guests Posted 02/10/06 11:41 PM Share Posted 02/10/06 11:41 PM Quote I have allway's loved modifying motors to make them go quicker, whether it be boats, bikes, cars, or mowers,Tim Allen, is that you? Joking aside, great work Dave getting the results you did with what you had and kudos to all those that helped you get there. Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443774 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 15d Gender: Male Location: Mackay NorthQueensland Posted 03/10/06 08:46 AM Author Share Posted 03/10/06 08:46 AM xrdreaming said: Well done mate, it is great to see. I think I have broken enough components for the both of us so you are have a great run without breaking things lol.The is a great time in your climate with the setup of the car, having done many runs myself, you know in your gut if the car has anything left in it. Do you think it was close to the best run you can do with the car in the current trim?Congrats once again,Dean←,thanks!I beleive the car as I ran it on sat, has a 10.8 - 10.75 in it.that would take a 1.55 60ft, which is realy on the edge, of the c/v's.a bit cooler weather would drop it more, but that is not going to happen up here for a while,maybe I should have had another go as it cooled off, but I felt that,I had got there without breaking anything, so I whimped out, it would not have sound as good if I had broke a c/v, in the next round. David Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443963 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 27d Gender: Male Location: Strapped in and holding on Posted 03/10/06 08:54 AM Share Posted 03/10/06 08:54 AM How did your Gtech times compare with the actual you ran. My pda is exact on ET, and got me excited in testing before I went to the track, which backed it up. You must have known you were going to go close?? Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443967 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 15d Gender: Male Location: Mackay NorthQueensland Posted 03/10/06 09:10 AM Author Share Posted 03/10/06 09:10 AM I don't try to get the best time out of the gtech,I do a smooth stedy start, change 2 as soon as the auto will let it, then to 3rd,this is about 25klmh, then I put my foot down, and let it do a pull through to 6300rpm.this gives me a hp or kw gragh similar to a dyno, this is done on a road that is level.because of the slow start, and having to pull in 3rd from 25k's, it only does about a 12.3 or there abouts. but it was showing up around 125klmph at the end.but when the car was standed, I tested it, and the times are close if the road is flat.but the mph alway's seemed to be about 3mph to much, but once you know this, you can just take about 3 off. David Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443978 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 4m 8d Location: Perth Posted 03/10/06 09:13 AM Share Posted 03/10/06 09:13 AM What tyres and suspension setup are you using? Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443980 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 15d Gender: Male Location: Mackay NorthQueensland Posted 03/10/06 09:17 AM Author Share Posted 03/10/06 09:17 AM M6 XR6T said: What tyres and suspension setup are you using?←stock 17inch rims allround, M/T street radial tyres on the back.suspenion is all stock,I wanted it to look like it just came off the showroom floor, Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-443983 Share on other sites More sharing options...
Mr Turbo Next stage, to the Pub in 10 seconds Member 2,777 Member For: 20y 8m 29d Gender: Male Location: Berwick Victoria Posted 04/10/06 02:23 AM Share Posted 04/10/06 02:23 AM Well done David I know how bad you wanted these times, and have worked hard in getting the results you truly deserve mate.Great to see the T set a new benchmark.Rob... Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-444390 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 15d Gender: Male Location: Mackay NorthQueensland Posted 04/10/06 04:55 AM Author Share Posted 04/10/06 04:55 AM thanks Rob, hows your car going? Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-444408 Share on other sites More sharing options...
Mr Turbo Next stage, to the Pub in 10 seconds Member 2,777 Member For: 20y 8m 29d Gender: Male Location: Berwick Victoria Posted 04/10/06 06:30 AM Share Posted 04/10/06 06:30 AM blueboost said: thanks Rob, hows your car going?←Ran the car for the first time since the upgrade (cooler, plumbing etc) Had to back off becasue the car was pinging so bad and at the same time shattered the plentury gears. The car rolled over the line still at 11.7 but only at 112mph (down 12mph) Has a 10 second pass it it for sure, just like your beast has done!Rob... Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-444459 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 15d Gender: Male Location: Mackay NorthQueensland Posted 04/10/06 07:17 AM Author Share Posted 04/10/06 07:17 AM yes I would say so, it almost had the potenial before. hope she works out for you. Link to comment https://www.fordxr6turbo.com/forum/topic/28942-blueboost-run-a-ten/page/7/#findComment-444479 Share on other sites More sharing options...
