WaRz0r Member 44 Member For: 19y 2m 22d Gender: Male Location: Brisbane Posted 24/09/06 10:29 AM Share Posted 24/09/06 10:29 AM Hey guys, Just got my car dynoed and my 02 xr6t only made 184 rwkw? I have a kn filter and the capa chip running the 10psi tune. Is there somthing wrong with my car or is this normal? thanksCraig Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/ Share on other sites More sharing options...
FSIX Member 566 Member For: 19y 7m 8d Posted 24/09/06 10:30 AM Share Posted 24/09/06 10:30 AM You say Capa chip, do you mean edit flash box?Yes it sounds low, it should pull that number stock. Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-439998 Share on other sites More sharing options...
jeromie0 Member 49 Member For: 18y 9m 27d Posted 24/09/06 10:31 AM Share Posted 24/09/06 10:31 AM I have found that cars can differ by up to 15% from the factory, but it will also depend on what dyno you are doing - hub or wheels - if it was dyno with the shootout mode or the other type and what gear they were testing your car on. Also, what is your AFR for the run? Can you post a copy of the dynograph? Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-439999 Share on other sites More sharing options...
WaRz0r Member 44 Member For: 19y 2m 22d Gender: Male Location: Brisbane Posted 24/09/06 10:40 AM Author Share Posted 24/09/06 10:40 AM Here is a post of the dyno give me some advice!!! thanks Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440007 Share on other sites More sharing options...
WaRz0r Member 44 Member For: 19y 2m 22d Gender: Male Location: Brisbane Posted 24/09/06 10:43 AM Author Share Posted 24/09/06 10:43 AM Yes its the edit flash box with the standard tunes.....seemed low for me as I also thought it should be that stock.... Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440008 Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 11m 26d Gender: Male Location: Canberra ACT Posted 24/09/06 10:46 AM Share Posted 24/09/06 10:46 AM That Dyno graph is absolutely hopeless!Not your fault, just the dyno operator should have reset the scales to give you a more detailed result before printing your read out!I cant see the AFR's, and the power scale is set way too high! Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440011 Share on other sites More sharing options...
WaRz0r Member 44 Member For: 19y 2m 22d Gender: Male Location: Brisbane Posted 24/09/06 10:47 AM Author Share Posted 24/09/06 10:47 AM give me a sec and I will post anotherone I have Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440016 Share on other sites More sharing options...
XR68UZ XR68UZ Donating Members 732 Member For: 19y 4m 23d Location: Sydney Posted 24/09/06 10:48 AM Share Posted 24/09/06 10:48 AM my car makes 194rwkw stock Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440017 Share on other sites More sharing options...
WaRz0r Member 44 Member For: 19y 2m 22d Gender: Male Location: Brisbane Posted 24/09/06 10:51 AM Author Share Posted 24/09/06 10:51 AM heres another is this better? Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440020 Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 11m 26d Gender: Male Location: Canberra ACT Posted 24/09/06 10:54 AM Share Posted 24/09/06 10:54 AM WaRz0r said: heres another is this better?←Is that from a different dyno mate? Link to comment https://www.fordxr6turbo.com/forum/topic/28754-under-rwkw/#findComment-440023 Share on other sites More sharing options...
