GT290 Member 320 Member For: 19y 6m 14d Location: Brisbane Posted 24/09/06 08:12 AM Share Posted 24/09/06 08:12 AM Fu(k that Shane! sorry to hear about it mate.. :( Link to comment Share on other sites More sharing options...
Guest Guests Posted 24/09/06 08:12 AM Share Posted 24/09/06 08:12 AM The plugs are about 2000kms old - the others are just fine.It only had a new bottom end put in it - why would you re-tune it? And the plug wasn't over tightened - although I fail to see how that would have broken the end off it??←the plug has vapourised due to detonation!!!is this why the first motor blew?retune it!!!! Link to comment Share on other sites More sharing options...
no turbo Member 206 Member For: 19y 2m 1d Posted 24/09/06 08:21 AM Share Posted 24/09/06 08:21 AM The original motor is absolutely fine - it was replaced as precaution.409RWKW's will do that.It is running the same tune as previously - comp ratios, nothing has changed?? Link to comment Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 19y 6m 27d Gender: Male Location: Bendigo Posted 24/09/06 08:29 AM Share Posted 24/09/06 08:29 AM The original motor is absolutely fine - it was replaced as precaution.409RWKW's will do that.It is running the same tune as previously - comp ratios, nothing has changed??← it advisable anyway when you do any component change, as we can see the cost of a dyno session could have rectified this fault Link to comment Share on other sites More sharing options...
no turbo Member 206 Member For: 19y 2m 1d Posted 24/09/06 08:47 AM Share Posted 24/09/06 08:47 AM (edited) I still do not think it was detonation.The plug may have simply failed.Was your car tuned on the road? Edited 24/09/06 08:47 AM by no turbo Link to comment Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 19y 6m 27d Gender: Male Location: Bendigo Posted 24/09/06 08:48 AM Share Posted 24/09/06 08:48 AM I still do not think it was detonation.The plug may have simply failed.Was your car tuned on the road?← it is definetly detonation, have seen it time and time again Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 11m 27d Gender: Male Location: brisbane Posted 24/09/06 09:52 AM Share Posted 24/09/06 09:52 AM sorry to hear F6 Link to comment Share on other sites More sharing options...
Guest Guests Posted 24/09/06 09:56 AM Share Posted 24/09/06 09:56 AM The original motor is absolutely fine - it was replaced as precaution.409RWKW's will do that.It is running the same tune as previously - comp ratios, nothing has changed??←this may be so the plug is an iridium or platnum plug designed not to melt or vapourise in upto 100,000k's it has melted why do you think this is?consider yourself lucky it has not cost you motor 2 from the sounds of it and retune it!!!I refused to tune nesh's car to the limit cause his previous tune had melted a plug to not even this extent!!!run it at 300 for a month if still ok then bring it back upto 409good luck with it!!! Link to comment Share on other sites More sharing options...
Muzza No V6 for me thanks!! Donating Members 583 Member For: 19y 5m 22d Location: Newcastle Posted 24/09/06 10:09 AM Share Posted 24/09/06 10:09 AM Holy sh*t Shane!!!! Man that sux.Hope you sort it out without to much trouble.Muzza. Link to comment Share on other sites More sharing options...
LTSBGY Member 259 Member For: 19y 11d Posted 24/09/06 10:46 AM Share Posted 24/09/06 10:46 AM The original motor is absolutely fine - it was replaced as precaution.409RWKW's will do that.It is running the same tune as previously - comp ratios, nothing has changed??←this may be so the plug is an iridium or platnum plug designed not to melt or vapourise in upto 100,000k's it has melted why do you think this is?consider yourself lucky it has not cost you motor 2 from the sounds of it and retune it!!!I refused to tune nesh's car to the limit cause his previous tune had melted a plug to not even this extent!!!run it at 300 for a month if still ok then bring it back upto 409good luck with it!!!←Now that the plugs have been changed and the car tuned, do the plugs need to be checked at any certain point after seeing a plug in that state? Or will it be fine because it has been tuned? Can detonation happen again after it has been tuned?Nesh Link to comment Share on other sites More sharing options...
