RAP1D Member Donating Members 3,739 Member For: 18y 11m 3d Gender: Male Location: Sydney NSW Posted 17/09/06 09:05 AM Share Posted 17/09/06 09:05 AM Started to put on a bigger IC and make up new pipes today.I used a core similar to the hybrid one they sell for the xr6t and made up new 2.5in pipes. Theres some parts I will redo during the week and need to make new brakets but its on and farout it makes a huge improvement... my 8psi map now hits 11psi The bottom section of pipe out of the IC is what I will change as it hangs a little too low, kind of just all squeezes in under the cover, so I'll extend the pipes and lift it up. I will make a new pipe that goes under the headlight as that is a 2in pipe so there's a nasty restriction, just need to mount the sensor which is what stopped me from making it today. Once that section is done I'll make up a new pipe that goes from the headlight to the TB. All in all its happy boosting days here. Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/ Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 1m 12d Gender: Male Location: Melbourne,S.E Posted 17/09/06 09:11 AM Share Posted 17/09/06 09:11 AM (edited) RAP1D said: Started to put on a bigger IC and make up new pipes today.I used a core similar to the hybrid one they sell for the xr6t and made up new 2.5in pipes. Theres some parts I will redo during the week and need to make new brakets but its on and farout it makes a huge improvement... my 8psi map now hits 11psi The bottom section of pipe out of the IC is what I will change as it hangs a little too low, kind of just all squeezes in under the cover, so I'll extend the pipes and lift it up. I will make a new pipe that goes under the headlight as that is a 2in pipe so there's a nasty restriction, just need to mount the sensor which is what stopped me from making it today. Once that section is done I'll make up a new pipe that goes from the headlight to the TB. All in all its happy boosting days here.←looking good rapid all coming together now look foward to the finish. and how did you go about puting the boost sensor in etc.Carlos. Edited 17/09/06 09:11 AM by Black ThundeR Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-436919 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 19d Gender: Male Posted 17/09/06 09:37 AM Share Posted 17/09/06 09:37 AM Good job mate IMO shouldnt you have droped the cooler a bit lower.Got any pics with the bar on? Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-436929 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 6m 12d Gender: Male Location: NSW Posted 17/09/06 09:44 AM Share Posted 17/09/06 09:44 AM Well done mate. I think you should get a retune though. Also, is it a second hand cooler?, it looks like the fins have been pushed in. Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-436933 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 3d Gender: Male Location: Sydney NSW Posted 17/09/06 11:37 AM Author Share Posted 17/09/06 11:37 AM Its a new one, but yeah some fins look slightly at a different angle... and I bent a few at the top lolI can sit it lower which is what I want, but I'll look at that when I make the new headlight pipe which should bend down more to meet the cooler.I'll take some pics with the bar on tomorow... was too keen for a tgest drive today haha Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437021 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 19d Gender: Male Posted 17/09/06 11:48 AM Share Posted 17/09/06 11:48 AM I know what you mean as soon as I got my wog cooler I was out in the garage fitting the thing then went straight for a drive lol.Looks good mate I just think if it sit's a bit lower you will get more direct air flow. Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437037 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 3d Gender: Male Location: Sydney NSW Posted 17/09/06 11:53 AM Author Share Posted 17/09/06 11:53 AM Yeah I dont like it sitting this high, can go a good 2inches lower... just means more playing with pipes which I'm keen to do over the week, its a bummer when its your only ride though Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437042 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 2d Posted 18/09/06 12:29 AM Share Posted 18/09/06 12:29 AM Good job Chris dont know how you can be farked but yeh make a second set of pipes for me Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437193 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 3d Gender: Male Location: Sydney NSW Posted 18/09/06 04:27 AM Author Share Posted 18/09/06 04:27 AM Fat-Tony said: Good job Chris dont know how you can be farked but yeh make a second set of pipes for me ←Yeah mate I can do that for ya Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437269 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 11m 3d Gender: Male Location: Sydney NSW Posted 19/09/06 08:30 AM Author Share Posted 19/09/06 08:30 AM Update...I turned the IC upside down so the outlets are on the oposite sides and put back on most of the stock nasty hoses just to get it all back on and running again. But the good thing is the IC sits alot further down so I just have to re think the piping as the stock hoses are definately a restriction. With the new IC and stock hoses its alot better than the stock IC set up, as in it hits harder on boost but pretty much the same off boost. With the new IC and new 2.5inch piping its heaps better all over... alot more low off boost pull and hits boost earlier and pushes on boost alot harder, so the new pipes are definatly the way to go. No pics sorry, it got dark Link to comment https://www.fordxr6turbo.com/forum/topic/28582-new-ic-and-pipes/#findComment-437773 Share on other sites More sharing options...
