Tranny Trouble
YPURV4
  • Replies 63
  • loitering with intent
  • Member For: 21y 3m 8d
I'll chop yas all.
Cmon then Chopper, come on down! :stirthepot:
Can I have your mickey_t's, race fuel, ultra lean map and no license? hahaha, f*ckwit. Ive beat you before, and I'd do it again ya wog stooge. Bring your wifes volvo, you'll need it when your hideous lookin ping machine with kmart rims throws a rod out the block and needs to be towed to get a real tune.
another quality post :gunsfiring:
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 18y 6m 23d
Dont you just love it :stirthepot:
I know heaps about the BTR 4sp. What was the question again?
The problem is when in trip mod and I give it a boot the car revs then dosnt want to change into second so I have to tap it back to normal drive for it to work.
But the weired thing is it is fine in normal drive and sprot drive, and it also dose work in trip mod but has long as its not high revs and you givre it a smooth gear change.
Any help or idea would be great. :gunsfiring:
  • Sucker
  • Moderating Team
  • Member For: 20y 7m 2d
Do you mean when in 'performance' mode?
And don't mind the b!tchfight above....there must have been a link posted on woghaters.com or something :nono:
  • Member For: 19y 1m 27d
You are talking about 3 modes for your grabox : normal, sport drive and 'trip' mode by which I assume you mean "tiptronic style" where you have moved the lever over to the left and then flick the lever forward or backward to change gears.
The reason your gearbox doesn't want to change when you're in "trip" mode is BECAUSE YOU'RE SUPPOSED TO CHANGE THE GEARS YOURSELF!!!!
The box will do it for you in the other two modes.
Hope I interpreted what you were asking correctly, otherwise sorry for assuming you don't know how to change gears - perhaps I misunderstood your posts.
  • Member For: 18y 8m 6d
I was thinking the same thing, but I somehow doubt that someone would know about or how to use that mode.
  • Sucker
  • Moderating Team
I was trying the subtle easy-going angle.....but your post is just as good :nono:
  • TEAM BA
  • Member For: 19y 11m 19d
It doesnt sound like this is one of those Jet(D) moments,
by the sounds of it if your in performance mode and you are floring it and change up a gear manually (full throtle high RPM) it will not go up, if you are not under full load (say 4000RPM half throttle) it will go up when you manually select it, but if you are in normal mode and floor it then everything is fine....
not knowing anything about the autos I cant help here...
Nah nah nah I no how to shift, that's the problem when I shift the gears manualy it wont let it go into second gear when booting it, but like I said if you shift it slow and smooth it will go into second.
But in both the none manual( DRIVE,SPORT DRIVE) mods it fine.
