  • - Track Bound EVO III -
  • Member For: 20y 4m 19d
Gramps will be along to cover this tomorrow morning.
We have discussed at length, but I can't remember.. lol ..
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435350
  • Member For: 21y 2m 21d
255 if you can get a tyre in that width.
245's are better as they are less pront to sidewall flex and designed to fit the 8" rim
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435372
  • Member For: 19y 2m 19d
I talked to a tyre shop the other day and he said I could fit 275s on the back with the 8" rim. Ive had 265s on them and they fitted alright but I think 275s are a bit wide I was hoping someone has fitted this width of tyre before.
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435484
  • Formerly Turbo6
  • Member For: 22y 3m 27d
Mate, I have 275/30-20's on the back of my sedan on 9.5" wide wheels. You need a little guard rolling to fit. Not sure about the utes though.
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435497
  • Member For: 21y 10m 7d
  TornadoJudd said:
Whats the widest tyre you can fit on the rear of a Tornado with standard F6 18s?
From memory, you can leagally go up one size. (Cro can you confirm this)
I've fitted 255/40/18's on mine.
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435503
  • F6+300+
  • Member For: 20y 5m 27d
If it’s a Manual and you want longer legs in 4th for the ¼ mile then the obvious choice would be:
Toyo Proxes T1R
255/45ZR18
Rim size 8.0-9.0-9.5
OD=27”
Width=9.8”
769 revolutions per klm
STD tire from FPV is @
Dunlops sports 9000
245/40/18
Rim size 8.0
OD=25.6”
Width=@ 9.6”
811 revolutions per klm
You go for a wider tire but less diameter and squeeze it onto a 8” rim:
Toyo Proxes T1R
245/40ZR18
Rim size 8.5-9.0-10
OD=25.9”
Width=10.2”
801 revolutions per klm
For 19” like I have my choice would be”
Toyo Proxes T1R
255/40ZR19
Rim size 8.5-9.0-10
OD=27”
Width=10.2”
770 revolutions per klm
:spoton:
Edited by F6_Tornado
https://www.fordxr6turbo.com/forum/topic/28496-tyre-width/#findComment-435515
