  • - Track Bound EVO III -
  • Member For: 20y 4m 18d
  SCRIBR said:
wow what an indepth thread!
It really opens up alot of questions (obviously).. and makes me wish I remember some of my physics from year 11-12!
can't believe I read it all!! ... but I can see why some people don't post anymore :pooh: and I thought some of my posts were useless
can't beleive the size of spikos turbo! :spoton: (top of page 3... cant get the pics to show for me)
It ( the thread ) started well, but it's a touchy subject, and it's also a big $$ subject..
  • Replies 93
Posted Images
  • Yaris member
  • Member For: 18y 10m 13d
very true.. I supprised this hasn't come back into focus 2 weeks earlier!
I would love to tig myself up a plenum.. but I imagine its alot more work than gettin the bottom half and making stuff to fit to that.. a whole lot more!
are still running yours?
did u find alot better throttle respones with the shorter pipework?
I figure that is one of the major gains.
  • Member For: 19y 4m 20d
F6 UTE you obviously know much more about plenum/airflow than myself and all of what you said makes sense. I'm just wondering how the air flows through a front fed plenum when not making major boost, I.e. low rpm etc I've just read a couple of articles about all chambers not getting equal airflow, for example during low rpm the front cylinders get more air and under high rpm/high boost the rear cylinders get more air. Any merit to this?
I'm just eager to learn and make the right choices with my induction setup!
How'd you own plenum go anyways mate?
Air feed to rear cylinders off boost is helped by tapering the rear of the plenum, there is a formula for this, and it provides equal flow to all cylinders. The pcm also monitors afr's to each cylinder and alters injector pulse to suit.
My plenum worked exceptionally well, gaining 45rwkw with 4spi less boost peak, with higher gains through the midrange... I should take some 'propper' piks.
On the road, from 2000rpm the surge of torque is a massive improvement. Tyres are turning in 3rd gear before 3800rpm is on the dial.. I hardly find myself revving over 4500rpm, on the road. I run NO bov, aka the Nizpro setup also..
Throttle response?? well lag, what's that??
I can tonker around at 1500rpm in 4th and the car doesn't shudder or cough. ( not that I hardly do it, but she will do it!..)
  illusionzzz said:
Whats the benefit of not running a BOV, I just assumed you had to run one?
That's another argument alltogether!!
There's been a debate on it before, no conclusions - just opinion bashing..
  • Moar Powar Babeh
  • Member For: 19y 7m 11d
How does the PCM know the afrs of one individual cylinder with only on hego sensor? you running 7(?) hego sensors Ben..?
Im thinking about going back to no BOV. The only think that puts me off is the sounds of the turkey orgy is a hell of a lot louder and lasts a hell of a lot longer with out the bov..... :spoton:
I got nfi?? Just what I was told!!
  • 2 weeks later...
  • Member For: 19y 8m 23d
Firing order.
Althought, the sensor only adjusts the stft and ltft trims.. It works in banks. Not individual cylinder trims. Although the 6 cylinder only has 1 bank, unlike a V8, which has 2 banks.
So sorry, it doesnt adjust fuel individually based on cylinder :roflmbo:
  Headsex said:
Firing order.
So sorry, it doesnt adjust fuel individually based on cylinder :biggrin:
I actually think it was your 'mate' that told me. You know the guy, he tought you how to set boost duty cycles or whatever it is to maintaitn preset boost irrelivent of air temps. Same guy that blew a ringland on his Auto F6 from detonation......... from his own tuning :original:
Now there's some :blink::P
