Xr6t, Typhoon Bolt On Plenum
  • Member For: 19y 11m 7d
Spot on Robin...
I know of someone who fitted the Nitto plenum and they said "it blows up like a balloon." :stirthepot:
Not bad for $3500. :laughing:
Yep it's mine and Nitto are at this moment making a thicker gauge plenum, but to be fair to them they did not design it to run at 400rwkw + and around 30psi boost.
  • Replies 34
  • - Track Bound EVO III -
  • Member For: 20y 2m 15d
I am fabricating mine at the moment, I'm using 6mm, and 10mm.
Hope to have pix early next week.
3mm I would never have considered. WAY too thin to be completely comfortable with imo.
  • Member For: 18y 6m
as for what stiffeners have been used, there is no actual bracing internally in it, but, there is two folds across the top of it, and one down each side of the front cone section to the throttle... the folds alone would go a long way to stiffenening the panels
perhaps I need to bolt one down and pressure test it?? see just how much flex is in the sides/top
what sort of design is your plenum going to be f6??
this is inside my plenum
Edited by ebs_4l
No doubting theres alot of work gone into your plenum. The velocity stacks are te right idea too. If it was made of thicker material, it's not as easy to bend etc, unless it's annealed, but still do-able.
Mine is based on my theory of relativity. How relativly easy it will be..lol. Very simple design, and what fits nicely. Volume, I have no idea yet.. At the moment it's only a top half replacement. I'm waiting on some materials for a complete lower half change, but that will be a completely different designed top half..
The only thing I'm doing differently is trying to increase velocity, as opposed to just upping the volume. It might not work, but it can't be too much worse than the stock one if all else fails.... fingers crossed.
  • Member For: 19y 7m 12d
Looks like you've put a lot of time and effort into your plenum. Great Job. Love seeing people coming up with their own stuff.
Are all the runners different lengths (eg tuned length).
I was also told (so dont shoot me down cos I dont know) that the BA responded well with out the bellmouth runners. EB may be different! I got no idea with these plenum design!
TOP JOB!
  • Next stage, to the Pub in 10 seconds
  • Member For: 20y 6m 17d
I don't want to be critical of anyone's endevaours, on the contrary I always encourage it. But I read on the other post about this same plenum that it is made from 3 mm Al plate. Given the large surface area and the load characteristics of a turbo engine, ie up to say 30 psi boost one minute and -30in Hg next the dynamic loading can play havoc with sheet metal manifolds. If you watch one on a dyno you can see the deflection in the walls of the manifold. That is why OEM manifolds have thick cast walls as a minimum 6-8mm thick.
Therefore I would ask what internal ribbing has been used to strength this manifold. Rob's (Mr Turbo) manifold is made from S.S so it is mechanically more rigid. The reasons I ask is I have seen a number of similar manifolds that fail, either with stress cracks (most minor) or major blow-ups (at the drags), and I wouldn't want someone who obviously cares a lot about their car have to experience that situation.
Cheers
Robin.
Agree with ya Robin! Here is a pic of my plenum for the members who havnt seen it before.
Rob...
  • Member For: 21y 11m
Regarding thickness of materials. Ally aint cheap. In most instances 3mm is fine, easy to work with and cheaper (still expensive) to buy.
6mm is an way overkill IMO (I original thought about using 6mm) but after looking into it I reckon 4mm should cope fine for high boost on the above shown manifold. Only the big TIGs will do 6 or 10mm ally also. Most small tigs do 3mm.
I'm generally a tight as.s, and not into overkill, but when it's a plenum, It's really not that much more, in the scheme of things.. Especially when you're not paying $1600-$3500 for a branded item..
I beleive 3mm is fine, I will pressure test one to be sure, but like I said, my manifold is made from the same stuff, and has an area probably double the largest flat area of this plenum, it is tough, and hasnt caused any problems with 17psi...
as for the big dollar plenum blowing up like a balloon, I have looked at the photos of it, and my opinion is that it is most likely made from very thin material?? considering its shape, even if it is made with a 3mm wall thickness, which I wouldnt think it would be, it is most probably made from a lower grade alloy, that is commonly used in all hammerforming techniques, it is more malleable/soft
and also, xlnt6 stated that mr turbos plenum is made from s.s so it is mechanically more rigid... I beg to differ, that plenum is certainly made from alloy.
we have a cigweld 200A inveter tig, its an awesome piece of gear to have in your back shed.. does 6mm no worries, I weld the plenum with 100-110A.. it has full digital controls, gaslens nozzles, and a swivel/flexible head.. cost $7.5k with all our accessories
Edited by ebs_4l
