boosted_sa Member 270 Member For: 19y 7m 12d Posted 31/08/06 12:58 PM Share Posted 31/08/06 12:58 PM I think you'll be pritty safe to say that it would out flow the std plenum by a mile! not sure bout the Nizpro though, should come close. Looks similar to Mr Turbos plenum. Link to comment Share on other sites More sharing options...
rapidchris Member 314 Member For: 19y 7m 6d Gender: Male Location: brisbane Posted 01/09/06 06:52 AM Share Posted 01/09/06 06:52 AM were abouts are you located im very interested Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 5m 1d Gender: Male Location: Melbourne, Victoria Posted 01/09/06 07:04 AM Share Posted 01/09/06 07:04 AM I don't want to be critical of anyone's endevaours, on the contrary I always encourage it. But I read on the other post about this same plenum that it is made from 3 mm Al plate. Given the large surface area and the load characteristics of a turbo engine, ie up to say 30 psi boost one minute and -30in Hg next the dynamic loading can play havoc with sheet metal manifolds. If you watch one on a dyno you can see the deflection in the walls of the manifold. That is why OEM manifolds have thick cast walls as a minimum 6-8mm thick.Therefore I would ask what internal ribbing has been used to strength this manifold. Rob's (Mr Turbo) manifold is made from S.S so it is mechanically more rigid. The reasons I ask is I have seen a number of similar manifolds that fail, either with stress cracks (most minor) or major blow-ups (at the drags), and I wouldn't want someone who obviously cares a lot about their car have to experience that situation.CheersRobin. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 9m 11d Gender: Male Location: Sydney NSW Posted 01/09/06 08:56 AM Share Posted 01/09/06 08:56 AM Looks good. Is it the same size/design as on you EB ebs_4l? Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 5d Gender: Male Location: Victoria Posted 01/09/06 09:33 AM Share Posted 01/09/06 09:33 AM Spot on Robin...I know of someone who fitted the Nitto plenum and they said "it blows up like a balloon." Not bad for $3500. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 01/09/06 09:41 AM Share Posted 01/09/06 09:41 AM Spot on Robin...I know of someone who fitted the Nitto plenum and they said "it blows up like a balloon." Not bad for $3500. ←nonono thats the boost controlled auto volume compensating plenum system..Geez dont you guys knwo anything... Link to comment Share on other sites More sharing options...
ebs_4l Member 16 Member For: 18y 6m Posted 01/09/06 09:43 AM Author Share Posted 01/09/06 09:43 AM this is my car, a turbo eb, makes 328rwkw on 14psi so far, the plenum is a lot bigger, about 11-12l volume, has trumpet runners inside the manifold... as for air distribution, I have a fuel trim of +9% cyl1 +6% cyl2 +3% cyl3 and -2% cyl6.. with my autronic SM4it is also made from 3mm sheet alloy, and hasnt given a problem, 3mm is vey tough stuff, no way im ever going to hurt it...as for 30psi boost, if you were running that much, then maybe you could use 4mm, BUT, honestly, how many cars on this forum are running 30psi boost?? id bet probably none... even 20-25psi is a hell of a lot, and I cant see that giving any problems with the plenumlocated at kadina S.Acheers, brad Link to comment Share on other sites More sharing options...
ebs_4l Member 16 Member For: 18y 6m Posted 01/09/06 09:48 AM Author Share Posted 01/09/06 09:48 AM this is my exhaust manifold Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 01/09/06 09:50 AM Share Posted 01/09/06 09:50 AM Very nice work mate. I've followed the buildup on FF.com.au for a while. You've done a great job. If your planning on selling this stuff just be aware of the rules about sponsorship on here the mod's can be a bit grumpy at times.. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 5d Gender: Male Location: Victoria Posted 01/09/06 09:55 AM Share Posted 01/09/06 09:55 AM If your planning on selling this stuff just be aware of the rules about sponsorship on here the mod's can be a bit grumpy at times.. Yep. I've edited out a few details. Link to comment Share on other sites More sharing options...
