Ian Member 56 Member For: 20y 8m 15d Gender: Male Location: Mackay Posted 30/08/06 06:28 AM Share Posted 30/08/06 06:28 AM Afternoon all, After spending 5 minutes trying to work out how to remove the cover of the wing mirror, I spat it and decided to ask any of the brains on here how it is done.Older Falcons had a screw under the mirror but all that is there now is a small plate. Reason for this is to see why my mirror won't adjust up or down, only in and out. Any help would be appreciated.cheersIan Link to comment https://www.fordxr6turbo.com/forum/topic/28132-wing-mrror/ Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 2m 27d Gender: Male Location: Sydney Posted 30/08/06 06:51 AM Share Posted 30/08/06 06:51 AM You can remove the outer mirror cover, the colour coded bit......There are 3 tabs, put pressure on the cover so when you release the tabs, it will progressively move away.Grab a long bladed flat screwdriver, and angle the mirror away from the tab you are working on. Push the tab away from the lug you are working from, and put a little pressure so the tab doesn't click back into place.Repeat this process for the other two tabs, and it sould come away. It is hard to describe, but once you have done it, you will know exactly what I am on about! Hope this helps! Link to comment https://www.fordxr6turbo.com/forum/topic/28132-wing-mrror/#findComment-428406 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 3d Gender: Male Location: Perth, WA Posted 30/08/06 06:55 AM Share Posted 30/08/06 06:55 AM The outer shell is a "clip on" design, and I have found no easy way of removing them.They have 3 or 4 lugs, which catch on plastic clips inside the black part of the mirror, and what I have done is to leverage with a screwdriver, until the clips let go.The catch is that some the lugs on the coloured part of the mirror may break if you are unlucky, and then it's time for the super glue I had a look in the Ford manual, and there is no description on removing the part, so it is probably not designed to be removed.Hope this is of some help. Link to comment https://www.fordxr6turbo.com/forum/topic/28132-wing-mrror/#findComment-428410 Share on other sites More sharing options...
Ian Member 56 Member For: 20y 8m 15d Gender: Male Location: Mackay Posted 30/08/06 07:38 AM Author Share Posted 30/08/06 07:38 AM Thanks fellas, got the cover off without too much damage only to find the motor inside a moulded section. Guess Ford will be getting a bit more of my hard earned Link to comment https://www.fordxr6turbo.com/forum/topic/28132-wing-mrror/#findComment-428437 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 9m 20d Gender: Male Location: The 8th Dimension Posted 30/08/06 08:50 AM Share Posted 30/08/06 08:50 AM Had to replace my drivers mirror after someone clipped the mirror and spread the wreakage for about thirty meters after where I had parked.Two things to watch out for, their are two screws hidden under the door card and be very careful not to drop the screws into the door as they are a bastard to get out. Other than that its an easy job you should have everything back together in under an hour. Link to comment https://www.fordxr6turbo.com/forum/topic/28132-wing-mrror/#findComment-428466 Share on other sites More sharing options...
