agentorange Member 20 Member For: 20y 9m 11d Location: Albury/Wodonga Posted 24/08/06 11:23 PM Share Posted 24/08/06 11:23 PM Hi all,I just took the T in for service and have noticed that the intercooler manifold cover has started to flake off where it says turbo. The whole plastic cover is brittle and soon the whole finish will peel off. Ford dealer tells me no go on warranty as it is a trim issue! Anyone had similar? Can I get it replaced under warranty? Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/ Share on other sites More sharing options...
agentorange Member 20 Member For: 20y 9m 11d Location: Albury/Wodonga Posted 24/08/06 11:35 PM Author Share Posted 24/08/06 11:35 PM Added the photo's Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426504 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m Posted 25/08/06 12:05 AM Share Posted 25/08/06 12:05 AM A part of the car that the surface is not exposed to sunlight or wear and tear, only thing its exposed to is heat from the motor, which the paint should be able to handle, tell them to fix it or you are taking further action, or go to another dealer. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426511 Share on other sites More sharing options...
jordak Member 1,226 Member For: 21y 12d Posted 25/08/06 12:31 AM Share Posted 25/08/06 12:31 AM Fat-Tony said: A part of the car that the surface is not exposed to sunlight or wear and tear, only thing its exposed to is heat from the motor, which the paint should be able to handle, tell them to fix it or you are taking further action, or go to another dealer.←Won't make any difference, this has been a "Within tolerence, not warranty" position of Ford since way back when. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426525 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 27d Gender: Male Location: Brisbane Posted 25/08/06 01:00 AM Share Posted 25/08/06 01:00 AM I think everyone has suffered the same fate after a year or two. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426546 Share on other sites More sharing options...
Superoo Member 340 Member For: 22y 7m 20d Gender: Male Posted 25/08/06 01:10 AM Share Posted 25/08/06 01:10 AM Different story here - had mine changed under warranty.Explained that I had no mods and that they couldn't guarantee that these "flakes" weren't going to cause a problem when they ended up all over the engine bay.Try another dealer. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426552 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 3m 11d Gender: Male Location: Melbourne,S.E Posted 25/08/06 03:52 AM Share Posted 25/08/06 03:52 AM maybe you should start to look after you engine bay abit better lollille dirty. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426585 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 5m 29d Gender: Male Location: Perth, WA Posted 25/08/06 08:10 AM Share Posted 25/08/06 08:10 AM I would be concerned Had to have my turbo repaired, as the compressor vanes suffered damage from what could have been a small amount of coating coming off on the inside of the piping Make sure you check the compressor wheel of your turbo for damage (just remove the intake piping from the turbo), so that you have a case while your car is still under warranty Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426663 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 8m 11d Gender: Male Location: NSW Posted 25/08/06 08:37 AM Share Posted 25/08/06 08:37 AM Mine has only just developed 2 small flakes at 150,000km. Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426678 Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 6m 4d Location: nowhere in particular Posted 25/08/06 09:08 AM Share Posted 25/08/06 09:08 AM saleen said: Mine has only just developed 2 small flakes at 150,000km.←You forgot to mention the flake behind the wheel Link to comment https://www.fordxr6turbo.com/forum/topic/28021-warranty-issues/#findComment-426686 Share on other sites More sharing options...
