deano59 Member 40 Member For: 20y 3m Gender: Male Location: Rowville, Victoria Posted 22/08/06 02:16 AM Share Posted 22/08/06 02:16 AM Hi all, I have a slight problem which I need some advice on, on odd occasions the engine management warning light will come on after start up with the engine running but no response when the accelerator is pressed. If I restart the car all is ok, what would cause this?The other issue is that I have an edit and wonder if this problem needs to be rectified by Ford will the error code if any be wiped when I flash back to standard mode prior to taking it back to Ford.Any advice much appreciated.ThanksDeano Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/ Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 11d Posted 22/08/06 03:10 AM Share Posted 22/08/06 03:10 AM Might be a bad flash upload, reflash the upload and see how it goes. Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425110 Share on other sites More sharing options...
Guest newl Guests Posted 22/08/06 03:12 AM Share Posted 22/08/06 03:12 AM Possibly faulty TPS. Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425111 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 1d Gender: Male Location: Sydney Posted 22/08/06 03:17 AM Share Posted 22/08/06 03:17 AM newl said: Possibly faulty TPS.←At a guess, that's what I reckon it is too.Very common.New accelerator pedal assembly for you! Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425115 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 5d Gender: Male Location: Mackay NorthQueensland Posted 22/08/06 04:28 AM Share Posted 22/08/06 04:28 AM sounds to me like what the generic tune does to some cars,tell me does it rev up to around 1500- 2000 rpm when it does this?if so it is easy to fix with a custom tune.if it is a custom tune, take it back to them, and they will fix it no worries. David Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425131 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 8m 8d Gender: Male Location: Perth, WA Posted 22/08/06 04:47 AM Share Posted 22/08/06 04:47 AM that's a TPS for sure... zero throttle response is the giveaway. Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425141 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 11m 5d Gender: Male Location: Mackay NorthQueensland Posted 22/08/06 08:44 PM Share Posted 22/08/06 08:44 PM XXXR6T said: that's a TPS for sure... zero throttle response is the giveaway.←the 0 throttle is the car protecting it self, flash back to standed and the problem will be gone, so it will be just a bit to much throttle opening at start up.the generic tunes are known for it. David Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425481 Share on other sites More sharing options...
2fardown Member 526 Member For: 19y 11m 20d Gender: Male Location: Brisbane Posted 22/08/06 11:09 PM Share Posted 22/08/06 11:09 PM blueboost is right. Mine used to do it all the time. Flash back to stock and it's perfect. Link to comment https://www.fordxr6turbo.com/forum/topic/27937-engine-warning-light/#findComment-425507 Share on other sites More sharing options...
