Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 6m 6d Gender: Male Location: Brisbane Posted 21/08/06 10:18 AM Share Posted 21/08/06 10:18 AM Mate there is no reason why you cannot upgrade piece by piece as money comes available or you get the feel you like. Braided hoses and better brake fluid,Better padsBetter calipers / pads and then Better rotorsMy 2cScotty Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 11m 21d Gender: Male Location: brisbane Posted 21/08/06 10:38 AM Share Posted 21/08/06 10:38 AM If your stock brakes did not pull you up fast enough because the ABS kicked in, then bigger brakes will not make any difference.Getting better tyres will make a difference, brakes will not.If you were cooking your stock brakes at the track or doing some spirited driving, then bigger brakes work better as they can stop more before they cook, but they will NOT stop the car quicker.This is because once ABS kicks in, you are at the limit of the tyres grip, not the brakes. Oh and stock brakes do suck, 6 spot Brembos rock ←we had a QLD skid pan day and about 6 guys were teaching us all about the cars handling and braking.. The braking lesson was interesting.... it was more then obvious that that the PBR kits stopped quicker then the standard brakes... then after that the Brembos were next best... but Harrop brakes took the day.. pulled the car up much quicker.The standard brake cars and the premium (pbr) brake cars had the same tyres... the cars definately pulled up quicker with premium brakes by quite some margin. Im sure the guys involved cn indicate distance.just an observation on the day that was pointed out by the instructors Link to comment Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 19y 8m 20d Location: Canberra Posted 22/08/06 03:01 AM Share Posted 22/08/06 03:01 AM Firstly, thanks for all the responses. Looks like my cheap upgrade is pointless, and I may as well put the $400 towards a $2000 upgrade .. If your stock brakes did not pull you up fast enough because the ABS kicked in, then bigger brakes will not make any difference.Getting better tyres will make a difference, brakes will not.←While my head agree's with you, my experience doesn't. I had various brake upgrades on cars in the past, even cars that I could lock up with the standard brakes, I found could stop a hell of a lot quicker with real brakes.←I'm no physicist, but I gotta say I'm with johng on this one. Not looking for any argument with you, Zap, but I'm SURE I read lots of stuff about bigger/better brakes being able to stop you quicker, given all other things remain constant.I agree fully that better tyres will help you stop quicker too, but I think you'll find that in two otherwise identical cars, but one with PBR brakes and the other with stockies, the PBR equipped one will pull up quicker, even with ABS activated in both.I'm sure someone can come up with the technical reason why, but I can't explain it too well. Imagine a tiny pad pressing onto a rotor. Pressed hard enough, it will 'lock' the rotor (and activate the ABS), but it won't be able to slow down the momentum of the rotor WITHOUT locking it very quickly at all. Now take a huge pad with a massive surface area, it would easily slow down the hefty rotor quite quickly - does that make any sense? Link to comment Share on other sites More sharing options...
eMPee Member 247 Member For: 20y 10m 15d Location: Sydney Posted 22/08/06 06:39 AM Share Posted 22/08/06 06:39 AM Does anyone know if the PBR upgrade will fit under 16" wheels? I need the 1 tonne rated wheels so I cant go any bigger :( Link to comment Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 7d Posted 22/08/06 08:42 AM Share Posted 22/08/06 08:42 AM Does anyone know if the PBR upgrade will fit under 16" wheels? I need the 1 tonne rated wheels so I cant go any bigger :(←You need 17" for the PBR's - and then they just fit.Regards,aa Link to comment Share on other sites More sharing options...
eMPee Member 247 Member For: 20y 10m 15d Location: Sydney Posted 23/08/06 09:10 PM Share Posted 23/08/06 09:10 PM bugger!cheers aiboart, maybe there is an option for people like me stuck with 16' wheels, I'll have to follow that up. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 11m 9d Gender: Male Location: Sydney Posted 24/08/06 10:42 AM Share Posted 24/08/06 10:42 AM Firstly, thanks for all the responses. Looks like my cheap upgrade is pointless, and I may as well put the $400 towards a $2000 upgrade .. If your stock brakes did not pull you up fast enough because the ABS kicked in, then bigger brakes will not make any difference.Getting better tyres will make a difference, brakes will not.←While my head agree's with you, my experience doesn't. I had various brake upgrades on cars in the past, even cars that I could lock up with the standard brakes, I found could stop a hell of a lot quicker with real brakes.←I'm no physicist, but I gotta say I'm with johng on this one. Not looking for any argument with you, Zap, but I'm SURE I read lots of stuff about bigger/better brakes being able to stop you quicker, given all other things remain constant.I agree fully that better tyres will help you stop quicker too, but I think you'll find that in two otherwise identical cars, but one with PBR brakes and the other with stockies, the PBR equipped one will pull up quicker, even with ABS activated in both.I'm sure someone can come up with the technical reason why, but I can't explain it too well. Imagine a tiny pad pressing onto a rotor. Pressed hard enough, it will 'lock' the rotor (and activate the ABS), but it won't be able to slow down the momentum of the rotor WITHOUT locking it very quickly at all. Now take a huge pad with a massive surface area, it would easily slow down the hefty rotor quite quickly - does that make any sense? ←I thought I would ask an Expert on this subject.At the FPV drive day, there were 4 instructors and all of them agreed with me that as long as the brakes were strong enough to activate the ABS or lock the wheels, the size of the brakes MAKES NO DIFFERENCE to braking performance, except after numerous stops. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 29d Gender: Male Location: Brisbane Posted 24/08/06 11:12 AM Share Posted 24/08/06 11:12 AM Exactly Zapper - even if the pads are worn out and it's metal on metal, once the ABS kicks in it doesn't matter how good they are.But repetitive breaking.......bigger is better Link to comment Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 3m 12d Gender: Male Location: NSW Posted 24/08/06 11:12 AM Share Posted 24/08/06 11:12 AM Exactly Zapper - even if the pads are worn out and it's metal on metal, once the ABS kicks in it doesn't matter how good they are.But repetitive breaking.......bigger is better ←lol@you contributing to techo threads. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 29d Gender: Male Location: Brisbane Posted 24/08/06 11:14 AM Share Posted 24/08/06 11:14 AM Exactly Zapper - even if the pads are worn out and it's metal on metal, once the ABS kicks in it doesn't matter how good they are.But repetitive breaking.......bigger is better ←lol@you contributing to techo threads.←lol@you lolling@meHaven't you got something useless to find and link us to? Link to comment Share on other sites More sharing options...
