Boost Leak
WaRz0r
  • Member For: 18y 9m 23d
Hey guys,
Just rang capa about my chip and they said I got a boost leak. With the 10Psi Tune, In first gear the boost only goes up to about 6psi for some reason? In about thrid gear it will hit 10psi but very very laggy. But if I am in a too high of a gear for the speed and I put my foot down the turbo will slowly sppol up to 10psi, but when I take off in first it will only go to 6psi. Seems to do it only when there is stress on the engine or somthing? Any tips on how to fins my boost leak?
thanks
craig
Guest newl
  • Guests
Perform all the normal stuff, check hoses, turbo bolts, things of that nature, maybe if you do have a boost leak something will jump out at ya when checking.
  • Member For: 22y 11d
Make sure you check the rubber between the Throttle Body and x-over pipe, as they are prone to splitting.
Also the hose behind the rhs headlight can come loose.
  • Member For: 19y 6m 14d
you'll find that you probably won't get the whole 10psi in 1st gear. My car will usually hit about 10psi in first, 12 in second, 14 or so in 3rd 15 in 4th and then last night it hit 17psi in 5th.. must have been the cold weather :tease:
  • Member For: 20y 8m
Sounds like its fine as there isnt that much load in 1st gear as there would be in say 4th. Check all pressure hoses especially the little ba5tard at the throttle body that you have to pull apart to make sure its secure (underneath slips like mine did). Could also be a faulty actuator although this is less likely.
is there anyway to check if your boost guage is correct?
flash the car back to standard, take it for a spin and in 4th gear give it a squirt. It should hover between 4.5 and 6psi. If it does this, then the boost gauge is ok :stirthepot: if it shows 2 psi or something, then its prob the boost gauge.
Also, take it for a spin with the 10psi tune, give it a squirt in 3rd or 4th and see what psi it makes then.
When I first put my new tune in, I noticed that 1st gear was boosting a little low, and when I rang Simon he told me to take it for a spin and check 4th gear.. turns out I had a leak anyways, as 4th would only make 10psi not 15. My leak was around the throttle body, I must have forgot to do it up properly :finger: as soon as I did that, it boosted to around 10psi in 1st, and 4th was back to usual :finger:
  • 9 years later...
  • New Member
  • Member For: 8y 5m 18d
Hey I have the same problem..get a spray bottle fill with water an dishwashing liquid or liquid laundry detergent. Start your car when cold an spray any connections, do around your turbo an exhuast first so your not spraying the liquid on hot exhuast turbo etc. For example my leak is where the turbo bolts onto the manifold! If theres a leak you will see the soapy water making bubbles?.
  • Member For: 17y 1m 10d
Thread was dormant for almost ten years, good find :)
Good tip also on the detergent.
