  • Member For: 19y 28d
I'm putting an AFR guage in and just wondering where to connect the signal wire to.
Does anyone know which number pin out it is on the ecu?
Thanks
https://www.fordxr6turbo.com/forum/topic/27642-installing-air-fuel-ratio-guage/
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
  • No V6 for me thanks!!
  • Member For: 19y 10m 11d
Thanks
Hi Rapid,
It conects to the grey wire that plugs into the O2 censor on the drivers side under your steering rod.
Easy :spoton:
Muzza.
Well that didnt work. I connected it to the grey wire an inch from the sensor, the guage reads lean all the time.
Maybe its the white wire??
I'll check mine again?
Ok it's tapped into the grey wire. Mine is a Autometer AFR works fine at idle it flicks from lean to rich put the foot down it stays around on rich back off around to lean...Al working ok you got the right wire going to the signal & the right wire goin gto the power??
Seems strange it's staying on lean.
I did a search
http://www.fordxr6turbo.com/forum/index.ph...topic=26279&hl=
Muzza.
  • Member For: 21y 11m 6d
I have the same problem, tapped into the grey wire, it reads lean all the time. mine is an Autometer Cobalt AIR FUEL ratio gauge. I was chatting to someone from the forum here and they took it to an auto electrician who ordered a ford part (im guessing from a GT or XR8, I think they come with AFR gauge) and now it works fine. but I dont know what part it is.
Edited by faygun
Yeah muzza its wired right, maybe mine has a different sensor to yours.
still 6psi Fattony, that's why I'm putting the guage in so I have a rough idea if it leans.
Thanks Decoy, Id love to put a wide band in it but Im not doing live tuning and dont care about exact ratios, just wanna see if it atleast looks like leaning.
