  • My new toy
  • Member For: 22y 14d
  ktford said:
  Macktheknife said:
  Wazza2 said:
Would anyone be able to post some dyno results of either a Phase 1 APS kit , 300kw exede kit or any other phase 1 type kits.
I'd love to but I 'll be stuffed if I know how to.
Anyone want to give me instruction?
What's that Trev, you are looking to be told?
Scotty
No scotty he is just on the pills again. :finger::finger::finger:
Ian
I will see if I still have mine.
  • 1 month later...
  • Replies 409
  • Member For: 21y 28d
;) great topic, well I just picked up my xr6t and breaking it in , ive talked to boys at brad garlick (herrod workshop) they can take you as far as you want I guess its the same , it comes down to $$$$$
anyway they can do exhaust, intake and new computer without avoiding the factory warranty, but the said the same as aps if you want to go over 300kw you need bigger squirters and when you break the integrity of the donk that’s when ford voids the warranty
so for about 3-4k you can go to 300kw maybe 320 but then its up to you
and the bloke on the other end of the dyno hahaha :lol:
  • In Your Face
  • Member For: 22y 1m 27d
surfsup hi and :hiwelcome: to the forum if your going to spend 3 to 4 grand you'll go higher than 300kw, l wouldn't bother with the exhaust mod unless you go APS my view anyway :thumbsup:
  • My new toy
Welcome but I would get that warranty issue in writing because I very much doubt that this is the case.
Ian
  • Member For: 22y 6m 24d
Ahhh, it's good to see this relic of a thread up and running again.... One thing I have noticed since however long ago I started this thread.....
How many people have got mods other than APS and Chiptorque?
I think the majority of mods are done by APS, and a few people are runing the XEDE from Chiptorque but does anybody use the others? I can only think of a couple that have gone down the Nizpro route.....a few people who have gone capa then got rid of it.....so far no one has gone AVO and as far as I know there is only one member using the dynomotive product (not suprisingly ;) )
I'm sure these are all great products but I would be interested to hear a bit about the not so publicised products out of curiosity.
Cheers,
Chris
  • FORD FORD FORD
  • Member For: 22y 1m 19d
Yes, you'd need documents & multiple copies of them IMO.
Scotty
  • SportCompact.biz
  • Member For: 22y 1m 24d
Cheers,
Chris
I'd say this is a reflection of the quality and engineering of the various offerings. You can either have backyard hack style, or OEM like quality, your choice :)
Guest FatBAt
  • Guests
  alxr6t said:
  Quote
Man I cant wait for the warrenty period to be up!!! APS has done a hell of a job <Picture: div20.gif>
To steal a quote from the opposition I JUST WANT ONE!
I don't get it why does everyone one say they will wait for there warranty period to be up? If you modify your car you void your warranty so if something goes wrong you will have to pay for it to get fixed. And once your warranty period is up you will have to pay for anything that needs fixing, so either way the end result is the same, you will pay! So why wait if modifying is what you want to do?
Try and explain that to the wife...
  • 1 month later...
  • Member For: 22y 4m 12d
  bdennis said:
Great topic. :spoton:
Lets not forget the Warranty issues though.
I spoke to my local service manager and he advised that the engine managment system will be able to detect and log any changes to boost etc. (Given that I have a good relationship with this dealer I tent to think this is a true statement!)
So if people are planing on making mods and then removing them before a service / warranty repair then you may be in for a shock!? I know most people make these upgrades with this in mind but there will be a few who may assume things...
Each to their own..
Good luck.
my 2c worth.. :w00t2:
Very true, but the whole idea behind the various chips/boost boxes is to prevent the factory PCM from seeing more boost than factory tolerances allow, as it will otherwise pull down the boost by other means than the wastegate, I.e. valve timing or ignition timing!
The moment the PCM sees overboost, it will pull the boost down to a "safe" level, and only after some time of driving with no further overboost, or after stopping and turning the engine off, and then back on again after a few seconds, will the boost return to the modified setting.
I have been running a CAPA 8-9 psi kit for a year now, and had absolutely no problems with the engine or driveline.
Only observation is that the engine management appears to change a lot under different conditions, and the boost has to be calibrated very accurately.
What I am seeing at the moment is a boost spike to 11 psi, after which the boost stabilises on about 8.5 psi.
The car is fast enough to whip Holdens SV8 in manual!
Like other posts on the forum, I would also like to get rid of the "jet lag" and have the boost come on earlier and stronger, even though my car is not too bad.
  • FORD FORD FORD
hey Ninka,
long time no hear, are you planning as many others are to change injectors, fuel pump & springs?
Scotty CCC
