XR6T4ME Member 186 Member For: 21y 8m 14d Location: Melbourne Posted 13/11/03 03:15 AM Share Posted 13/11/03 03:15 AM Thanks for the response guys, I may go the flange option so I can refit it if required. As per my sig I have a 2.3Lt engine with twin 48mm Webbers with big exhaust in my other toy. And I know how annoying cabin drone is when just cruising. The last thing I want to do is mimic that in a 2003 model car! The XR8 snorkal will be my other mod after my run in period expires. So hopefully I will get to enjoy the T more when the foot is firmly planted.One question, with the mods to exhaust and intake does the factory chip need retuning or does it pick the diff in flow and adapt to it? Is it adviseable to get dyno'd?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-64565 Share on other sites More sharing options...
Guest Guests Posted 13/11/03 03:58 AM Share Posted 13/11/03 03:58 AM I like mine,SWMBO was away when I did it,didnt pick a thing ! Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-64578 Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 3m 17d Gender: Male Location: Sydney, NSW Posted 13/11/03 11:35 AM Share Posted 13/11/03 11:35 AM so what's the best value for money then??Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-64671 Share on other sites More sharing options...
Guest Guests Posted 13/11/03 08:41 PM Share Posted 13/11/03 08:41 PM Dave,has to be centre muff,get the flange jobie so you can back to stock anytime.Some bloke went up in pipe size and got drone, so stay same pipe size, no drone.vik Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-64695 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 11d Gender: Male Location: Sydney Posted 14/11/03 12:13 PM Share Posted 14/11/03 12:13 PM Guys,Removing the centre muffler definitely adds power. As for drone it's a subjective issue.... and I did go up in size to 2.5". The centre muffler does do a lot for noise reduction, which is why it's there. The approach taken was also to look at what can be done with the rear muffler to alter the sound, with some very good results today ... a very deep sound much like a V8.... but a few other major things have also been done. I'll write a paper next week on what's been looked at, as the work is not quite finished, but it's looks like another option.FYI, here's a pic of the guts of the rear muffler.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-64894 Share on other sites More sharing options...
Guest 56Mainline Guests Posted 16/11/03 08:25 AM Share Posted 16/11/03 08:25 AM My goodness gracious Brian! What have you been doing, what with butchering the rear resonator? Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-65218 Share on other sites More sharing options...
Guest tim Guests Posted 18/11/03 02:37 AM Share Posted 18/11/03 02:37 AM Hi, I just wondered if anyone had fitted the APS chip and sprts Cat as per the car on their website and was in Motor and what they thought of the change in character of their car. Tim Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-65738 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 11d Gender: Male Location: Sydney Posted 18/11/03 10:53 PM Share Posted 18/11/03 10:53 PM Quote Posted on Nov 16 2003, 06:25 PM My goodness gracious Brian! What have you been doing, what with butchering the rear resonator?I've got a new exhaust after the turbo dump pipe back, larger 3.5” down pipe, 3.5”high-flow new style cat with steel-mesh internals and ceramic coating (for higher gas temps & faster flowing gas), larger dual 2.5” diameter pipe all the way back, prototype rebuilt rear muffler to accommodate larger dual 2.5" pipe instead of the stock 2" pipe, so a very low restriction, free flowing exhaust…. It looks stock from the rear, as I’ve retained the rear tip, and it has a much sportier sound mid-range, overall a very deep sound. I drove from Sydney to Melbourne yesterday. The otherwise stock car feels like it comes on boost a bit quicker, is smoother and more responsive. At freeway (123kmph) speeds, 2800 revs, it is fairly quiet inside the car with no drone. This is a prototype exhaust, much better than standard, as I wanted a good exhaust set-up (and high-flow cat) before the major Nizpro upgrade that is happening now.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-66004 Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 22y 3m 1d Location: Perth W.A. Posted 19/11/03 02:48 AM Share Posted 19/11/03 02:48 AM brianhave you been getting any wastegate flutter just after cold start when you are warming it up a bit.I was trying a 3.5 inch system for a company. it was a good sound and gave an extra 14 rwkw, but after a while it started with the wastegate flutter and I dicided to go back to stock for now. Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-66052 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 11d Gender: Male Location: Sydney Posted 19/11/03 03:34 AM Share Posted 19/11/03 03:34 AM 1axr,No I did not notice a wastegate problem.Moving forward, both my wastegate spring and blow-off valve are being replaced as a part of the upgrade.... to handle higher boost pressure.I've had a number of wastegate problems in the past with others cars, however I wouldn't normally expect just an exhaust change to cause wastegate problems... having said that I don't know how weak the stock wastegate spring is, nor the extent of "wastegate creep". You can pressure test the wastegate actuator to see at what pressure it opens. (Don't ask me what is standard is). With other cars in the past I've had attempted remedies such as adjustable actuator arms, replaced items with stronger springs, cut/shorten/reweld actuator arms, and external wastegates.brian Link to comment https://www.fordxr6turbo.com/forum/topic/2761-modification-options/page/30/#findComment-66059 Share on other sites More sharing options...
