  • Formerly Turbo6
  • Member For: 22y 3m 25d
Hey dynosteve, make sure you keep us posted. I didn't realise that you were only in Redcliffe.
I have been talking with Chiptorque and am ready to go but I had better wait until you have some more news for me......... :D
I am itching to modify more!
  • Replies 409
  • Dyno Tuner
  • Member For: 21y 11m 27d
off to willowbank again tommorrow night, want to run the same boost as last time and try a bigger tyre which should put us into the mid 12's at least, then we'll turn up the boost.
  • Member For: 21y 11m 10d
Hey steve, what are the chances of you getting us some video footage of the car doing a run. I know most of us here on the forum would love to see it :D :thumbsup:
  • Member For: 22y 1m 3d
Dynosteve, based on what you said I know who it is also. There are no secrets in this world anymore in the age of the internet.
Anyway there are quite a few guys out there getting 550 rwhp with the 12 valve EA to AU head with big turbo. I'm quite sure 550 will be achieved with the stock GT40, even 600 (unless Ford turbine section strangles it as compressor is up to it).
500 rwhp from a turbo 6 on ultimate is nothing nowadays, its sooo easy. Its nothing to be in awe of. All that's needed are a high flowing fuel system, big turbo, intercooller exhaust, programmable fuel/ignition. Its 650 to 700 rwhp which is the awe benchmark
I completely disagree with you unigroup. Dont underestimate the GT40 turbo. The GT40 Compressor in the Ford has a max flow of about 58lbs/min. I have a turbo Expensive Daewoo 6 with a TO4 V Trim that flows 52lb/min and has a dyno proven 481rwhp. I have done a EA Falcon six with a TS04 (60lbs/min) which did high 400s only on lowish boost. Considering the GT40 is way more efficient (advanced) than the TO4 and TS04, (it will flow more air at a lower temperature), I have no doubts the compressor will go 500rwhp. As I dont know whats on the turbine I cant comment but from memory it was a low A/R and it is this, if anything which would limit power. In any case at 500rwhp it is out of its best efficiency range but it will certainly do it. Just wait and see, Dynosteve is nearly already there. I've already been there a few times with 12 valve heads. A 24 valve head should make it even easier.
Regards
Just to prove a point I looked at the Garrett Performance product catalog and they rate the GT40 for engines 370hp to 650hp. The GT40 has two compressor options. It has a wheel with a 82mm exducer and .58 A/R (the one Ford uses) and a 88mm exducer with .72 A/R .(no inducer sizes given)
However they (Garrett) use a 77mm turbine exducer and 1 to 1.34 A/R on their performance turbos as a match for the above compressor. I think Ford uses a much smaller turbine to keep lag at a minimum.
So based on how Garrett have matched their wheels you will find it will be the turbine that is on the small size for this turbo.
Regards
  • Dyno Tuner
will try and get some video footage for you guys, as to the 500hprw well if it's possible I'll get it but I think there's a few limiting factors yet to come into the combo. But hey it's all fun, to be totally honest I never built this car to make or sell upgrade kits I built it for myself to have fun in, my ultimate goal is to run a 10 second pass in the next couple of months but I might also find that I might be rebuilding a motor because I don't yet know what the weakest points are. Will keep you guys posted
  • SportCompact.biz
  • Member For: 22y 1m 21d
Good to see someone pushing the boudaries instead of being limited in their minds to what this car can do...
PS.. if the turbine is too small then change to a larger one.
