Damo Donating Members 403 Member For: 21y 5m 5d Gender: Male Location: Sydney Posted 08/08/06 04:37 AM Share Posted 08/08/06 04:37 AM What I am running isn't really allowed....OK, gotcha. Thanks dude. And don't worry, I won't tell anyone.It's a good thing there aren't any c0ps on this forum! Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418357 Share on other sites More sharing options...
Revved Member 59 Member For: 18y 9m 24d Posted 08/08/06 05:27 AM Share Posted 08/08/06 05:27 AM There are cops arnt there, swear I read replies from cops. we just dont care, not like we hurting anyone with lights... Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418374 Share on other sites More sharing options...
Damo Donating Members 403 Member For: 21y 5m 5d Gender: Male Location: Sydney Posted 08/08/06 05:48 AM Share Posted 08/08/06 05:48 AM Revved, I was joking. Of course there are... we have a pretty decent sample of performance car enthusiasts on here, chances are there will be more than one or two members of the constabulary!If they're illegal to unless certain conditions prevail, then they're illegal. They're called "Fog Lights" in my User Manual and everywhere else I've seen any official reference to them (such as features lists). I was pulled over and told they weren't to be used unless it was foggy or visibility was poor so I switched them off and haven't used them since, except in fog, etc. That's good enough for me. Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418379 Share on other sites More sharing options...
Eugene Member 670 Member For: 20y 7m 8d Gender: Male Location: Newcastle NSW Posted 08/08/06 06:01 AM Share Posted 08/08/06 06:01 AM The best thing to do would be remove the lights and add some ducts to help brake cooling, there in the perfect spot.←Wouldnt that be illeagle, removing factory fitted safety device to fit a non approved performance modification? Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418381 Share on other sites More sharing options...
SavageF6 Donating Members 1,622 Member For: 21y 5d Gender: Male Location: Sydney Posted 08/08/06 08:47 AM Share Posted 08/08/06 08:47 AM I better remove those RPG launchers from where the foggies used to be then. Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418463 Share on other sites More sharing options...
Guest newl Guests Posted 08/08/06 09:19 AM Share Posted 08/08/06 09:19 AM <Quake II flashback>Hey, swallow a few of these pills!</Quake II flashback> Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418481 Share on other sites More sharing options...
Guest FatBAt Guests Posted 08/08/06 11:24 PM Share Posted 08/08/06 11:24 PM Road Transport (Safety and Traffic Management) (Road Rules) Regulation 1999 / Division 5 / Lights on vehicles / Clause 55aA person must not cause or permit:(a) any fog light affixed to a motor vehicle on a road to be lighted except in fog, mist or under other atmospheric conditions that restrict visibilityThis is NSW Legislation and may not be relevant in other states.Under the Australian Road Rules / Part 13 / Lights and warning devices / 215(3)a driver driving during the day in fog, or other hazardous weather conditions causing reduced visibility, may drive without the headlights of the driver’s vehicle operating if the vehicle is fitted with front fog lights and those lights are operating effectively and are clearly visible.and in the same217(1) / Using rear fog lightsThe driver of a vehicle fitted with a rear fog light must not operate the fog light unless the driver is driving in fog or other hazardous weather conditions causing reduced visibility.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418625 Share on other sites More sharing options...
Guest FatBAt Guests Posted 09/08/06 12:03 AM Share Posted 09/08/06 12:03 AM And another from Vehicle Standard (Australian Design Rule 13/00 – Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles) 20056.3. FRONT FOG LAMP6.3.1. Presence Optional on motor vehicles. Prohibited on trailers.6.3.2. Number Two.6.3.3. Arrangement No special requirement.6.3.4. Position6.3.4.1. In width: that point on the apparent surface in the direction of the reference axis which is farthest from the vehicle's median longitudinal plane shall not be more than 400mm from the extreme outer edge of the vehicle.6.3.4.2. In height: Minimum: Not less than 250mm above the ground. Maximum: For M1 category vehicles not more than 800mm above the ground; For all other categories of vehicles no maximum height. However, no point on the apparent surface in the direction of the reference axis must be higher than the highest point on the apparent surface in the direction of the reference axis of the dipped-beam headlamp.6.3.4.3. In length: at the front of the vehicle. This requirement shall be deemed to be satisfied if the light emitted does not cause discomfort to the driver either directly, or indirectly through the rear-view mirrors and/or other reflecting surfaces of the vehicle.6.3.5. Geometric visibility Defined by angles alpha and beta specified in paragraph 2.13., alpha = 5 degrees upwards and downwards, Beta = 45 degrees outwards and 10 degrees inwards.6.3.6. Orientation Towards the front. The alignment of the front fog lamps must not vary according to the angle of lock of the steering. They must be directed forward without causing undue dazzling or discomfort to oncoming drives and other road users.6.3.7. Electrical connections It must be possible to switch the front fog lamps on and off independently of the main- beam headlamps, the dipped-beam headlamps or any combination of main- and dipped- beam headlamps.6.3.8. Tell-tale Circuit-closed tell-tale mandatory. An independent non-flashing warning light.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418637 Share on other sites More sharing options...
Revved Member 59 Member For: 18y 9m 24d Posted 09/08/06 02:35 AM Share Posted 09/08/06 02:35 AM Just a quick check then if u do use the fog lights when your driving at night time, or on the high way, say yes in your reply if you dont say no, I do I always use them on highway and whilst driving at night. alot of my night driving is at the highway anyway.. Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418677 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 30d Gender: Male Location: Brisbane Posted 09/08/06 05:10 AM Share Posted 09/08/06 05:10 AM This is NSW Legislation and may not be relevant in other states......←Qld is something along the lines of 'not dazzling other road users' so it's purely open to personal interpretation (of the bloke in blue of course). Link to comment https://www.fordxr6turbo.com/forum/topic/27486-fog-lights-driving-lights/page/17/#findComment-418721 Share on other sites More sharing options...
