  • Member For: 18y 4d
Tom
Thanks heaps for the reply mate!! Im going to try and aquire the wiring diagrams from Ford for both the BFII Utes and Sedans and see what I can make of it....whilst awaiting my tax refund that is going to finance this...
Its going to be a few weeks but ill try to make up a little "how too" if im successful :)
WiLL
  • Replies 95
Posted Images
  • Member For: 18y 5m 3d
Ok who's doing a GROUP BUY???
we got 7.. I'll do it if I have toot??
How many yes's before I start the group buy thread.
Edited by ritzy
Quick Update, I managed to get my hands on the BF Series Wiring Diagrams, all 105 pages of them...and done a fair bit of research and all signs are positive....ive just got a few little things to test this weekend, hopefully my tax return will be in and the installation can begin!
WiLL
  • Member For: 17y 11m 2d
Hi All,
I was sucessful today in sorting out the Sedan switching and remote for the Lidlok in the ute.
I was going past the wrecker yesterday and grabbed a Boot Switch, Remote, and a sedan plug.
As I suggested earlier, the dash wiring is all the same and the boot release wiring is in place down to the main orange plug in the RH kick panel C396. The switch plug is tied back behind the Instrument Cluster along with the one for the fuel door release(that is also doable to if you can be bothered and you get a door of a sedan or wagon - the latch points on the fuel door are different between the ute and sedan/wagon).
You need to get a plug C396 off a sedan to steal the violet pin(84) out of the plug as it is not installed in the ute(the connectors are AMP so you could possibly get one from an auto electrician). My wrecker had a front cut and the plug you need is part of the loom that is cut when the chassis is split so that was part one sorted.
I pulled out the cluster and fed the plugs down to the switch. I then grabbed the switch and removed the fuel release switch as I wouldnt be needing it, and fitted a blank off the BA ute from below the driving light switch. You then plug in the boot switch and tape back the other plug to prevent rattles and fit the assembly into the dash.
Next you remove the RH kick panel and undo the orange connector C396 and take the Lidlok open wire(Red) and disconnect it from the Common Door Unlock(Red-Yellow) and solder it to the pin off the violet wire in the sedan plug removed earlier. You then fit the pin back into the empty slot(84) in the ute plug and reassemble the connector. Refit your trim.
Finaly, you pair the sedan remote to your car using the procedure in your owners manual and that's it! (Note - you need to pair all remotes for the car each time you do this procedure or the others will not work until you redo them....)
My Lidlok now opens off the boot switch in the dash and the boot release on the remote. It also locks off the remote lock key and the button on the ICC as it used to. I will probably do a instruction sheet with photos once I get back to work next week so I can PDF it and make it a sensible size. I think this is a better way of wiring it up as the lid can be unlocked separately to the doors and vise-versa.
The best part is that the parts only cost $50 from the wrecker. I have connected to the car and there are no codes generated so it would appear that the BEM does not expect a reply from the Boot Ajar when the Boot Unlock is used. :stirthepot:
Cheers
Tom
Edited by aussieturtle
  • Sucker
  • Moderating Team
  • Member For: 21y 1m 28d
:stirthepot:
Nice work. And I had only just convinced myself that I shouldn't be so lazy and just put up with the keyed locks. :spoton:
  • Member For: 18y 1m 14d
:spoton: top work turtle if only I understood what you just posted.... :censored:
guess I'll just have 2 wait for will to do it and then hand him a few beers so he can do mine 2
roger
  • Bored Member
  • Administrator
  • Member For: 22y 7m 8d
Why not go to the next step and get a automatic hydraulic lift the same as the new Maloo's have now as well...
Thanks heaps for the info Tom, im still waiting for my effing accountant to get my tax return done!!! If anyone would like the BF series wiring diagrams for help with this or future projects, pm me your email address, ill send u all 105 pages of it!! hahaha (sedan, ute, wagon all included)
WiLL
  MRAH33 said:
:spoton: top work turtle if only I understood what you just posted.... :slap:
roger
No worries Rog,
It is alot easier than I typed :wacko:
The how to with pictures is coming - if I could just get back to Sydney........
Cheers
Tom
