  • Member For: 21y 6m 7d
  tab said:
  Geeseman said:
  Dynowog said:
geeseman when quoting me quote me not trana and yes I know spiro uses ems but as far as I know he has never successfully done one / tried to do one into a t?
There are quite a few EMS tuners out there. To say that you are a part of an elite few is silly.
Try reading that again now Stevey.
EDIT: Just to clarify, when he said 't', he's referring to the Ford XR6 Turbo :tease:
I read it fine. To state again for those who do not understand there are quite a few ems tuners out there to suggest that none other than those mentioned by dw can tune ems on a xr6t is silly.
  • Replies 79
  Trough Lolly said:
  turbotom said:
  Trough Lolly said:
  turbotrana said:
..But it cant do the diff ratio..
would this be a problem if the EMS was used instead of edit??
What's the story trough....
aren't you happy with your edit tune?
tom
my tunes are fine what makes u think otherwise :spoton:
im just curious, but as DW states the edit is needed to change certain things still.
basically I was wondering could ems be used as a STAND ALONE ecu without the edit.
it can when retrofitting it to a xf/or a cortina for example etc
  Geeseman said:
EDIT: Just to clarify, when he said 't', he's referring to the Ford XR6 Turbo :spoton:
there are tricks to making them run and then smoothly that only vince and I know so it is posible for spiro to do it but he would need time to find these settings and wiring tricks out!
but once again yes I know spiro tunes ems and is within the top 5 ems tuners in sydney!!!!
ask him about revtronic! and if it got off the ground who was the first dealer inquiry!!!!!
  • EVO 9 SUPPORTER
  • Member For: 22y 1m 5d
Ok. I had EMS in my XR6T ute and I have EMS in my EVO 9 at the moment. I highly recommend it and I have had EMS in many cars previously and have no problems whatsoever. The only problem I had was the unbelievable power, my ute made 269kw at the wheels with just a 3inch exhaust and 10psi. The power was unbelievable and the Torque was enormous. My EVO 9 at the moment makes 238.7kw at the 4 wheels and only on 20psi, bear in mind they do come out factory 15psi. All I have is a good exhaust system, air filter and the EMS ECU. Standard the car made 148kw at the 4 wheels. The tuner is the most important as well. All my cars get tuned by V&E Rigoli Racing at Wetherill Park in Sydney's west NSW. He is a great tuner and I highly recommend him. Nick (dynowog) and Spiro are also tuners of the EMS ECU and for my knowledge are good tuners as well. Sorry about my gas bagging.
  • Member For: 22y 1m 3d
You dont have to be a brain surgeon to do an average tune which is usually what you get with fully programmable aftermarket EMS.
Getting the power is the easy thing. Getting the cold starts/temp corrections/decel mixtures-timing and few other drivability variables right is what makes a good tune.
Take it a step further then theres the tuner who also knows how to tune for economy/ power/emissions. Not many of them around.
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 10m 11d
And now has run an 11.90 at WSID yesterday :spoton:
Congratulations Joe and Vince that's a bloody quick time for the mods you have :wub:
  • EVO 9 SUPPORTER
  DBOSS said:
And now has run an 11.90 at WSID yesterday :tease:
Congratulations Joe and Vince that's a bloody quick time for the mods you have :tease:
Thanks Jeff. :tease: I am still slapping myself in dis-belief. :spoton:
  • EVO 9 SUPPORTER
that's why the tuner is the most important. Vince at V&E Rigoli Racing has had many cars such as Lancers and WRX's pass the EPA emmission tests at their inspection stations etc...
I've heard some really good things about V&E Rigoli and from owners of all types a modded cars sounds like he certainly knows his stuff,now all we need is for him to start tuning with the Edit as the NSW guys are busting for a good Edit tuner :fool:
CYA JEFF :tease:
PS:Joe change your sig you are in the 11's
Guest
This topic is now closed to further replies.
