4runner Donating Members 215 Member For: 20y 8m 25d Location: Sydney Posted 16/08/06 01:58 AM Author Share Posted 16/08/06 01:58 AM LeighD said: Can you please explain a little more about how you connected the ICC IR to the set top box?←The IR signal from the dash can be picked up from the ICC connector. I simply wired this up to a point inside the DVD/STB unit where I had cut the units own IR signal and replaced it with the car's one. Inside the Skymaster, there is a cable coming from the front panel (which has the display, IR and buttons) to the main board. Where this joins the main board, you can see the "IR" signal labelled.If you want I can probably take pictures of the auto switching cct and the IR patching inside the unit. Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-422121 Share on other sites More sharing options...
LeighD Donating Members 255 Member For: 20y 8m Location: Perth Posted 16/08/06 02:04 AM Share Posted 16/08/06 02:04 AM Thanks for that, I should be able to figure it out Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-422122 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 7m 8d Gender: Male Location: Mildura Posted 16/08/06 03:03 AM Share Posted 16/08/06 03:03 AM what aerial are you using, a mate of mine has done the STB mod and has tried numerous aerial with no luck. its nice and clear when stopped but as soon as u move its over.. Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-422138 Share on other sites More sharing options...
4runner Donating Members 215 Member For: 20y 8m 25d Location: Sydney Posted 16/08/06 04:49 AM Author Share Posted 16/08/06 04:49 AM Trough Lolly said: what aerial are you using, a mate of mine has done the STB mod and has tried numerous aerial with no luck. its nice and clear when stopped but as soon as u move its over..←I'm using a powered diversity antenna off ebay. Like this one Diversity Antenna . It's not very good whilst moving either - unless you're in Hobart under the transmitter up on Mount Wellington Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-422197 Share on other sites More sharing options...
voy74656 voy74656 Member 2,039 Member For: 21y 4m 30d Location: Adelaide Posted 26/10/06 04:11 PM Share Posted 26/10/06 04:11 PM Ive seen this setup in the flesh and it ROX!!! Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-454989 Share on other sites More sharing options...
Panda Member 225 Member For: 21y 4d Gender: Male Location: Gladstone, QLD Posted 26/10/06 11:07 PM Share Posted 26/10/06 11:07 PM 4runner said: I'm using a powered diversity antenna off ebay. Like this one Diversity Antenna . It's not very good whilst moving either - unless you're in Hobart under the transmitter up on Mount WellingtonJust one question on that antenna, what type of plug does it have? Every one of those diversity antennas I have seen has 3.5mm plugs. My TV Tuner card only has a ANT IN port, not 3.5mm.I got this antenna off ebay and same deal, it has decent reception when stopped, but when you move it goes to sh*t so I will have to keep on looking.Possibly this antenna, or this antenna. Panda Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-455068 Share on other sites More sharing options...
voy74656 voy74656 Member 2,039 Member For: 21y 4m 30d Location: Adelaide Posted 27/10/06 06:15 AM Share Posted 27/10/06 06:15 AM Read the entire thread last nighthttp://www.fordxr6turbo.com/forum/index.php?showtopic=10310The ultimate receiver would be:http://www.carconverters.com.au/products/T...tennas/304.html"Accept digital television signals at speeds up to 180kms per hour using this Digital Mobile Receiver DVB-T."Comes with a nice price tag 2 @ $430.52 AUD Inc GST Theres gotta be a better solution that doesnt cost as much... Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-455324 Share on other sites More sharing options...
Panda Member 225 Member For: 21y 4d Gender: Male Location: Gladstone, QLD Posted 27/10/06 06:33 AM Share Posted 27/10/06 06:33 AM voy74656 said: Theres gotta be a better solution that doesnt cost as much...There's always another solution.This TV Tuner with This antenna should be a pretty good combination.Downside thought is that it you would need to run this to a converter box to play it on your ICC. There are other TV Tuners out there which do output in NTSC, but they lack some of the functions that this one has.Just can't win......at least, just can't win cheaply!!Panda Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-455335 Share on other sites More sharing options...
voy74656 voy74656 Member 2,039 Member For: 21y 4m 30d Location: Adelaide Posted 27/10/06 06:52 AM Share Posted 27/10/06 06:52 AM Im still tossing up b/w dvd/digital TV Vs Carputer setup.Carputer setup has its advantages - LOT more work but I think the end result would be far more superiour. With carputer I'd have instant access to everything I want - its a computer so has all the functionality - can store all my dvd's/mp3's etc - use TVedia to access all the media - same as ive got running in the loungeroom with my MCE Remote - very handy. Plus can use HiP 2 map pc functions to the remote control.But the digital tv/dvd setup would be basically 'plug N play' setup.With your carputer setup Panda I noticed in another thread u had Google Earth tracking you. Is it possible to have live tracking of this so ppl can monitor where preeeecious is while shes on the road? Im guessing u need an active wireless connection for this or is this supported by google earth / Goops and the GPS connection??? Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-455353 Share on other sites More sharing options...
Panda Member 225 Member For: 21y 4d Gender: Male Location: Gladstone, QLD Posted 27/10/06 07:09 AM Share Posted 27/10/06 07:09 AM voy74656 said: With your carputer setup Panda I noticed in another thread u had Google Earth tracking you. Is it possible to have live tracking of this so ppl can monitor where preeeecious is while shes on the road? Im guessing u need an active wireless connection for this or is this supported by google earth / Goops and the GPS connection???It is possible to monitor where the car is at all times, but it is difficult. Basically you need to have internet connection all the time (GPRS enabled mobile, or possibly the Wireless Broadband) plus a GPS Receiver and carputer.Here's some info on Goops - http://www.mp3car.com/vbulletin/showthread.php?t=68799http://sites.onlinenw.com/goops/goops.phpWireless Broadband -http://my.bigpond.com/internetplans/broadb...wireless/about/Panda Link to comment https://www.fordxr6turbo.com/forum/topic/27377-another-dvdset-top-option-for-the-icc/page/2/#findComment-455363 Share on other sites More sharing options...
