Hazey Member 234 Member For: 21y 10m 15d Posted 01/08/06 02:53 AM Share Posted 01/08/06 02:53 AM (edited) Hi All,I have been invited to go to Eastern Creek tommorow Night. I have never taken my car down the strip. I have a few questions pleaseI have 260rwkw and is a 6sp Manual1) I have new 19" wheels on the car with 265 on rear. They are 1 week old. Should I run with these or put my stockers on with Dunlop Rubber about a few mm of tread2) Do I need to do a burnout - Just the with the 19" or 17" or both3) What tyre pressure do I run - again please specify 19" or 17"When I had the stockers the car would break traction in first and chirp 2nd. How is this on the strip will it affect times.Now with the 19" 265 it has heaps more grip and I cannot chirp.Thanks AlotAidan Edited 01/08/06 02:56 AM by Hazey Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/ Share on other sites More sharing options...
4runner Donating Members 215 Member For: 20y 10m 30d Location: Sydney Posted 01/08/06 04:21 AM Share Posted 01/08/06 04:21 AM Aidan,I'm not an expert in quarter mile times with a T (I've only run mine at one meet), but have had hundreds of passes in a high 9/low 10 sec dragster.My advice would be to only do a big enough burnout to dry the water off the tyres and clean them up. The difference in traction between a drag strip start line and the street is immense. I would suggest that if you are running the standard clutch then that could possibly be the weak point (slippage).As for tyre pressure, I have no idea. I ran mine with the standard 40psi I drive on the street with. With slicks, it would be a different story altogether.Good luck and have fun. Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415424 Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 11m 6d Gender: Male Location: Adelaide Posted 01/08/06 05:35 AM Share Posted 01/08/06 05:35 AM The standard 17" dunlops are quite good when they have tread.Your's sound like they are well worn.I got best 60' time running 20 psi on the dunlop sp3000.Do NOT need a huge burnout. Just enough to warm them up a little bit.As stated by 4runner, enough wheel spin to get the water off the tyres.If the 19's give you better grip on the street, they'll give you even more at the strip. Try and stage yourself so that you set up over a track section with plenty of rubber already laid into the surface. Rubber to rubber contact is very grippy. (line up behind a car with serious grunt running slicks, he's sure to prepare a good surface for you. Just be prepared to wipe off lots of rubber bits from the inside of your guards and rear skirts. )As to pressure on 19's ..... No idea, but generally lower pressures will provide a greater contact patch on the track.... The problem with too low a pressure is that the tyre can break its sealing bead... tom Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415441 Share on other sites More sharing options...
plj 59 Member 212 Member For: 19y 25d Gender: Male Location: brisbane Posted 01/08/06 05:46 AM Share Posted 01/08/06 05:46 AM 17s are good only when the tyre is fairly new, the rubber will be soft. when they are nearly worn out they have been heated to many times and rubber is hard.usually the bigger the profile the better the tyre bags, I run 17psi on stock dunlops you could go lower but at 12psi the tyres spin on rims Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415450 Share on other sites More sharing options...
Lawsy Wanabe mechanical engineer Donating Members 960 Member For: 20y 9m 4d Gender: Male Location: At the computer, obviously..... Posted 01/08/06 05:49 AM Share Posted 01/08/06 05:49 AM If I was in his situation, I'd definately be running the 17's. If he struggles to break traction with the 19s on, then the 17's on a prepared track will provide even more grip than his 19's. I'd say this would be ideal, since it doesn't matter if he tears them to bits and he'll probably get just enough slip to prevent the thing from bogging down.From what I've read on here and other places, with street tyres the pressure has only a slight effect on traction, but the best results are usually found while using 6-12 psi under the recommendation on the plaque (inside the door). So, if it says you should be using 32, then I'd be inclined to run 20-24, just depends on your preference... Some guys go lower, but there really isn't any point...You're only going to notice a slight difference; don't try taking any corners at speed while the pressure is down....[EDIT] Just take both tyres with you, if the 17's suck royally, then stick the 19's on. If you do happen to use the 19's though, then I suggest lowering the pressure much more than 8psi under... Just to be safe. But if geea or someone see's this thread, they should definately have much more accurate figures for you, since they know first hand what the right thing to do is.[/EDIT] Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415453 Share on other sites More sharing options...
IceMyButt Link Member 421 Member For: 21y 19d Gender: Male Location: Sydney Posted 01/08/06 05:52 AM Share Posted 01/08/06 05:52 AM Hazey,A few of us will be at the creek tomorrow night - Drop by and say gday - I have a black T, red plates.DBOSS (Jeff) and maybe Buf-Phoon (Jules) will be there.Phil Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415456 Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 11m 6d Gender: Male Location: Adelaide Posted 01/08/06 06:08 AM Share Posted 01/08/06 06:08 AM IceMyButt said: Hazey,A few of us will be at the creek tomorrow night - Drop by and say gday - I have a black T, red plates.DBOSS (Jeff) and maybe Buf-Phoon (Jules) will be there.Phil←mmmmm, sounds like showdown time.... Hope the weather is favourable.Have fun fellas.tom Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415465 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 1d Gender: Male Location: Sydney NSW Posted 01/08/06 07:15 AM Share Posted 01/08/06 07:15 AM Wouldnt the 19s get a higher termainal speed? Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415480 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 6m 6d Gender: Male Location: Strapped in and holding on Posted 01/08/06 08:33 AM Share Posted 01/08/06 08:33 AM If I were you, I'd run with the tyres which have more grip. Whether that better tread depth, or better compund.2.0 60' is a good time to get off the line in. I did this on Dunlops with 40psi. Not better off dropping the pressures on the 19's. 17's might show a little gain with dropped pressure. Don't ride the clutch tooo much, because with the better grip the wheels won't spin, and ALL the slip will be in the clutch = bad.. You'll be lucky to get 1 or 2 perfect launches. Do a burnout in 2nd gear.. Just drop the clutch in 2nd in the water, creep forward till your on the dry stuff, then sit near the limmiter for around 5 seconds . You will know when the tyres are sticky, coz the car will crab forwards and want to get going instead of spin.. Short shift 2nd ( 4500rpm ) so you don't go up in wheelspin when you stab the gas to get going again.Change each gear just above peak torque. Look at your dyno graph, it is a tool, and not just something to show how much powaaarr you got Good luck. Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415530 Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 20y 2d Gender: Male Posted 01/08/06 08:38 AM Share Posted 01/08/06 08:38 AM Hazey said: Hi All,I have been invited to go to Eastern Creek tommorow Night. I have never taken my car down the strip. I have a few questions pleaseI have 260rwkw and is a 6sp Manual1) I have new 19" wheels on the car with 265 on rear. They are 1 week old. Should I run with these or put my stockers on with Dunlop Rubber about a few mm of tread2) Do I need to do a burnout - Just the with the 19" or 17" or both3) What tyre pressure do I run - again please specify 19" or 17"When I had the stockers the car would break traction in first and chirp 2nd. How is this on the strip will it affect times.Now with the 19" 265 it has heaps more grip and I cannot chirp.Thanks AlotAidan ←Hi mate cant really say anything, been at the creek twic NO TRACTION on dunlops in a manual,Iam trying to lend a helmet so I can get out there as well.If I do get there ill try to track you down & say HI.CHEERS BB, Link to comment https://www.fordxr6turbo.com/forum/topic/27375-advice-for-qtr-mile-run-at-creek/#findComment-415532 Share on other sites More sharing options...
