  • Member For: 20y 6m 15d
  LightningXR6T said:
  Dynowog said:
  LightningXR6T said:
Hey Mickey G, does your car still rev up to 2000rpm on a cold startup. Mine didn't after the tune, but has started doing it again! Traction Control is switching off again as well.
try reflash it!!!!
Thanks Nick, I'll try it and let you know. By the way, If I put a 3.5" dump pipe with a metal cat into a twin 2.5" cat back system, what effects would it have on your tune.
I have already added the cat back twin 2.5" system and there does not appear to have any adveres effects!
Yeah mine still revs up hard at the start when cold. The TC switches off only when things get hectic and there is a consistant loss of traction under heavy work condition
other than that all is well.
Daryl why dont you change the cooler on your car first. It makes the car run better with the standard muffler, and its not an expensive mod.
How much is the cat baack 2.5"? does it sound different?
MG
Edited by mickey_gee
  • Replies 53
  • Member For: 18y 9m 16d
  mickey_gee said:
  LightningXR6T said:
  Dynowog said:
try reflash it!!!!
MG
Well, I see I'm not alone with these problems. :laughing:
I think I'll go see Dynowog today & see if he's found a fix yet.
Other than the cold start issue, I'm quite happy with the resulsts (270+rwkw) & you could even say...The results speak for them selves! :laughing:
  • Member For: 19y 9m 29d
  Dynowog said:
try reflash it!!!!
I tried it, still the same!
  mickey_gee said:
  LightningXR6T said:
  Dynowog said:
try reflash it!!!!
MG
I used a Redback Cat Back system. It's around $400ish. Hard to say if there has been any power gain, the note however is a bit deeper. Probably not worth it but I'm too lazy to take it off!
