  • Toughest BA Turbo
  • Member For: 22y 4m 6d
We need to see the boost graph.
That's the sort of result I'd expect if you were running say 0 to 2 lbs extra boost, and just Edit.
Brian
  • Replies 53
  • Member For: 19y 1m 9d
50rwkw gain aint nothing to sneeze at, that's more than 25% gain in power, and looks like your car has a real punch in the back at lower RPM. As others have mentioned 80kw down low, hell you must be able to feel that. Remember peak power aint everything, its how you develop your power in the rev range. Dyno aint a tool to see how fast your car is, its primarly a tuning tool. These other cars you mention that have a higher power figure with the same tune, did they have a higher RWKW figure to begin with? Did they get a 50rwkw gain. Also take into account the age and condition of your motor.
  • Team Bute
  • Member For: 21y 9m 15d
  ExAreSix said:
Oh, didn't realise HE tuned it. Go somewhere else, that is a sh*thouse result...
:wub:
:kissmy:
Should have known that.
Yep... It's a Nick tune!
Has WOG written all over the curve.... :tease:
Turn the graph upside down, and you'll see his signature "W" power curve! :kissmy:
tom
  • Gold Platinum Member
  • Member For: 20y 10m 4d
Wouldn't it be injectors? With unichip they say they can't go past your level without injectors...
  • Member For: 19y 9m 29d
Sounds like I have a pretty decent tune after all! You can really feel the extra punch.
All I might do is, put in a good tank of fuel and next time Nick's in Newcastle I'll give it another run on the dyno!
Thanks a lot guys! :wub:
  • Member For: 20y 1m 6d
Brian
You what?
You expect a standard car to gain 50rwkw with an edit that has no more boost added?
I would say every edit that adds power is adding boost surely?
  • - Track Bound EVO III -
  • Member For: 20y 4m 15d
Why get caught up in the peak hp figure??
How long does it spend at 6000rpms??
5% of it's life??
You drive around with that fat midrage all day, and get the most punch from it..
The gain there is huge..
