  • Member For: 18y 1m 26d
  • Gender: Female
dang sorry to hear XF_Falcon
so was wondering I had a look under the T with out jacking it up or anything and couldn't see a thing
I could feel something like a circular shape with bolts on each side about a size 13 - 15 and line coming off each end the thing is , the line feels stiff not flexy is that normal ?
don't got any jack stands etc, I read the thread on not using the stock jack but I always do for oil changes im going to scab a decent pair of stands etc
  • Replies 32
  • Here since the start...
  • Member For: 22y 1m 5d
Having trouble undoing the pipes on the fuel filter is quite common. Good quality pipe spanners will help.
  • Gender: Female
so with my post above, does that sound like im feeling up the filter, due couldn't see a thing under neath
and I can get fuel filters for $12 each w00t
  • Forged Member
  • Member For: 18y 3m 23d
yeah, that sounds like the filter mate, the lines are solid cos they carry fuel and you don't want those rubbing thin!
  • Dropping a turd
  • Member For: 17y 7m 4d
There is a trick to undoing the filter. One is a 19mm and the other a 14mm I think. What you do is position the 19mm which is on the filter against the body in the undoing direction. So as you turn the 14mm the 19mm presses against the body. if you still cant budge it hit the 14mm openender with a hammer or use a tube on the spanner to get more leverage.I changed one on a BA and it was so tight and the one on my EF was easy to remove. If I had just held both spanners in my hand I would not have been able to remove the filter on the BA . Arron
Edited by arronm
  • <put funny sh*t here>
  • Member For: 18y 6m 22d
Ok well I'm due for my 40K service now, so I'll find out if this is something they change on this service or not. If they do I'll get them to change it, and see if they will use my new filter and just take that off their price of the service? dunno we'll see!
  • Into the laaaake
  • Member For: 17y 11m 16d
  XF Falcon said:
I think the fact that my jack only lifts the car up so much, and it only gives me a little bit of room to work with under the car doesnt help. its very hard to put a lot of force into it when the car is only like 1 inche above your chest.
Best xmas present ever!!! Min Height 63mm. Max Height 500mm.
Edited by hanra
ooooooooooooo yeah, where the hell did you buy that from mate?? I've been looking for something like that for years!
  • Into the laaaake
I got it through Rapeco. Its an Omega jack. Something that they usually dont stock on the floor, have to ask to see there book for em then order it.
The Jack was $352 but that was on the cheaper side as I have a friend who works there.
