While on the topic of sound quality and rattles, if using the back speaker thin arse metal panels when remounting use foam tape between the speaker panel and the mounting surace of the car, they are flimsy POS and even with a decent speaker that actually offers midrange, unlike the stock speakers, they rattle more than enough to be annoying.
Good post none the less Trough just means I gotta pull the back of my car apart now lol
make a whole new speaker panel from 6-10mm MDF, while your at it convert the 5x7's to 6x9' or 6.5'. nothing awesome for the back is necessary, its only "rear fill". a set of 2 way coax 6.5's will be perfect.
TurboCrazy: any decent audio shop should be able to get "Dynamat" or "roadkill" sound deadening products.
a "dynamat extreme large pack" is just perfect for doing the rear wall and doors. :laughing:
hehe if I could be bothered I would remake the rear section outta mdf or I will just get my mate to do it prob easier that way
  • Replies 41
  • Member For: 18y 11m
trough lolley... where is your sub mounted and how big? my 12" is behind passengers seat but in a non-custom box.. it just fit in there from last car so I chucked it in.. would like some pics/ideas on good accoustic sub mounting ideas..
I dynomatted when I got the 6x9's and the 6"splits.. I just went to mates shop and cut it off his heavy duty roll..
did the whole cabin and doors.. even braced up speaker supports with mdf..
so much quieter on the road and heaps deeper sounds.. didnt cost me much when they get it in 100m rolls!
  • Member For: 20y 7m 12d
no special box for me, I just made the biggest bas*ard I could fit behind the passenger seat to suit the 15' sub. sealed enclosure probly about 2 cubes.
going to make a new one soon to put my 2nd 15' in. one is going behind the passenger seat and the other will sit right in the middle. we're gunna have to do alot of fart assin around to get the right volume as we are gunna try make this one a ported setup. aiming for about 40hz. :laughing:
going to make a new one soon to put my 2nd 15' in. one is going behind the passenger seat and the other will sit right in the middle. we're gunna have to do alot of fart assin around to get the right volume as we are gunna try make this one a ported setup. aiming for about 40hz. :pinch:
sounds mad.. I see windscreens popping and trim exploding :laughing:
roughly what size could I get away with for a 12" and which way to face it? it's facing forwards and into the seat which obviously muffles it a fair bit..
  • Here since the start...
  • Member For: 21y 11m 25d
whats a "dynamat extreme large pack" worth..?
$280ish I "THINK".... :laughing:
maybe it was $190rrp, im not sure. I bought half a pack off a mate for $90.
According to the US disributors site the bulk pack is $270 US.
I've seen some on Ebay for $210 AUS plus about $20-30 freight.
$280ish I "THINK".... :blink:
try your local install "specialists" and ask how much per metre off the roll.. they buy bulk and its rediculously cheap.. I think my whole ute cost me $70 and I used equivilant to 2.5 heavy duty paks.. its not like the weight is gunna matter :spoton:
going to make a new one soon to put my 2nd 15' in. one is going behind the passenger seat and the other will sit right in the middle. we're gunna have to do alot of fart assin around to get the right volume as we are gunna try make this one a ported setup. aiming for about 40hz. :spoton:
in a ute its not really gunna matter what way it faces unless its a bandpass set-up. even then it wont matter :pinch:
mines facing the passenger seat.
  • Member For: 21y 5m 14d
Thanks to Hiddeous and Adam for the advice and the link to this thread in regard to my now-closed post about road noise in my ute.
I have now purchased some Dynamat and hope it will introduce some quiet to the ute cabin.
Thanks guys,
Peter
Edited by cro142
Let us know how you go with it Peter.
If it all works out I'll be doing the same.
  • Sucker
  • Moderating Team
  • Member For: 20y 11m 26d
Has the matting done anything to lower the noise from the vents though? You'd still get that hollow airflow/road noise sound wouldn't you?
