ugy Donating Members 199 Member For: 19y 3m 30d Location: Auckland Posted 17/07/06 09:23 AM Share Posted 17/07/06 09:23 AM Hi guys, been having a problem with the T missing and surging down the strip.It happens about 2 thirds down and does it every time.I have had the valve springs done so that wont be the problem. I thought it might be the fuel pump (which it sounds like) but every one I suggest it to reckons it wouldnt be. I have had it on the dyno to try and find out but nothing shows up. Would be grateful if somebody can help out. Thanks. Link to comment Share on other sites More sharing options...
dalts Member 755 Member For: 18y 8m 24d Gender: Male Location: brisbane Posted 17/07/06 09:29 AM Share Posted 17/07/06 09:29 AM Hi guys, been having a problem with the T missing and surging down the strip.It happens about 2 thirds down and does it every time.I have had the valve springs done so that wont be the problem. I thought it might be the fuel pump (which it sounds like) but every one I suggest it to reckons it wouldnt be. I have had it on the dyno to try and find out but nothing shows up. Would be grateful if somebody can help out. Thanks.←how much fuel do you have on board,as sometimes if the fuel is relatively low,this can happen Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 1m 12d Gender: Male Location: In my house Posted 17/07/06 09:29 AM Share Posted 17/07/06 09:29 AM How much fuel are you running down the track with and what mods you got done? Link to comment Share on other sites More sharing options...
DesFlurane Member 351 Member For: 18y 10m 1d Gender: Male Posted 17/07/06 09:30 AM Share Posted 17/07/06 09:30 AM He had a full tank to aid traction! Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 30d Posted 17/07/06 09:31 AM Share Posted 17/07/06 09:31 AM have you been running it with low fuel down the strip? Link to comment Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 2m 14d Gender: Male Location: Adelaide Posted 17/07/06 09:31 AM Share Posted 17/07/06 09:31 AM Yep mine is a bas*ard with under 1/2 tank the swirl pot in these some of these cars can,t keep up,and the faster you get the more fuel you need or get a surge tank fitted Link to comment Share on other sites More sharing options...
shockF6 Member 478 Member For: 19y 4m 15d Location: Melbourne Posted 17/07/06 09:32 AM Share Posted 17/07/06 09:32 AM if the fuel in your tank is lower than the top of the intank pump housing then you are probably running out of fuel in the "slosh tank". Try sticking to more than 1/2 a tank in your car when running WOT for long periods of time.another option is to install a surge tank under the bonnet Link to comment Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 3m 30d Location: Auckland Posted 17/07/06 09:45 AM Author Share Posted 17/07/06 09:45 AM Thanks for the fast reply guys. Sorry forgot to mention I had at least 3 quaters of a tank. Link to comment Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 3m 30d Location: Auckland Posted 17/07/06 09:55 AM Author Share Posted 17/07/06 09:55 AM How much fuel are you running down the track with and what mods you got done? ←Hi Tranny 3 quaters of a tankMods: IC, valve springs, CAI, Injectors, Flasher and no Cat.Cheers Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 30d Posted 17/07/06 10:03 AM Share Posted 17/07/06 10:03 AM did you do any of these mods after the flasher, and are you running a generic or custom tune Link to comment Share on other sites More sharing options...
