xlnt6 Donating Members 350 Member For: 20y 4m 10d Gender: Male Location: Melbourne, Victoria Posted 13/07/06 02:34 AM Share Posted 13/07/06 02:34 AM Hi all,Just wondering if anyone has gone to the bother of retrofitting a Typhoon oil cooler (engine oil not transmission), onto their XR. The phoon comes with one that fits directly onto the block (where the oil filter is) and then the oil filter screws to the cooler. The cooler is water cooled and goes inline with the metal line that comes out of the thermostat housing and goes round to the heater pipe. Mines a manual, so I don't have any thermo valve in that line (I think the auto does). That means I probably can just cut the line so I can tap into it for the cooler.I figured it was an easy install as all the parts are off the shelf, and if they use them on the phoon, FPV must have figured that a higher than standard power car probably needs one for engine durability.Also speaking with a mate, he said that the BA phoon uses the Boss oil filter (shorter in height), but there is sufficient clearance to use the stocko F9 filter. The BF cooler has a different oil filter thread so the preferred one to use is a BA type.I was going to do some track work, so I though the cooler was a good idea. Has anyone looked at this at all ?CheersRobin. Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 5m 18d Gender: Male Location: Perth, WA Posted 13/07/06 04:08 AM Share Posted 13/07/06 04:08 AM Have you looked at the F6 setup? This would give you a good idea as to how its fitted, maybe get yourself a copy of the F6 manual CD? Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 4m 10d Gender: Male Location: Melbourne, Victoria Posted 13/07/06 05:28 AM Author Share Posted 13/07/06 05:28 AM Have you looked at the F6 setup? This would give you a good idea as to how its fitted, maybe get yourself a copy of the F6 manual CD?The F6 setup is the one I am referring to. I've never seen an F6 specific manual. I have a copy of the Ford manual for the XR series, but would be interested in a CD copy of an F6 manual if one exists ?Robin. Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 5m 18d Gender: Male Location: Perth, WA Posted 13/07/06 05:51 AM Share Posted 13/07/06 05:51 AM I'm pretty sure it does. I know you were talking about the F6 setup, I just meant have you actually had a look at one close up to get an idea of how its positioned... Link to comment Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 19y 2d Gender: Male Location: Sydney Posted 14/07/06 12:22 AM Share Posted 14/07/06 12:22 AM As an aside, it looks like the "new" stubby filter is standard on all BFs, not just the V8s. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 1m 19d Gender: Male Location: Perth, WA Posted 14/07/06 12:36 AM Share Posted 14/07/06 12:36 AM Hi all,Just wondering if anyone has gone to the bother of retrofitting a Typhoon oil cooler (engine oil not transmission), onto their XR. The phoon comes with one that fits directly onto the block (where the oil filter is) and then the oil filter screws to the cooler. The cooler is water cooled and goes inline with the metal line that comes out of the thermostat housing and goes round to the heater pipe. Mines a manual, so I don't have any thermo valve in that line (I think the auto does). That means I probably can just cut the line so I can tap into it for the cooler.I figured it was an easy install as all the parts are off the shelf, and if they use them on the phoon, FPV must have figured that a higher than standard power car probably needs one for engine durability.Also speaking with a mate, he said that the BA phoon uses the Boss oil filter (shorter in height), but there is sufficient clearance to use the stocko F9 filter. The BF cooler has a different oil filter thread so the preferred one to use is a BA type.I was going to do some track work, so I though the cooler was a good idea. Has anyone looked at this at all ?CheersRobin.←I have fitted one of these.Easy to do, just order the 'bits' from Ford (see attached).Just be careful to get the the right fitting to retain the cooler to the block. It must have the smaller 'old' size thread on the end where it screws into the block, and a slightly larger thread on the opposite end where the oil filter goes.pm me if you need more info.Oil_Cooler.pdf Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 11d Gender: Male Location: Sydney Posted 14/07/06 05:14 AM Share Posted 14/07/06 05:14 AM I did this ages ago, you have to order new water pipes as well.Also, the old AFL1 doesn't fit anymore, a new filter will be used. Link to comment Share on other sites More sharing options...
caspertt Donating Members 47 Member For: 18y 11m 15d Gender: Male Location: Toodyay, WA Posted 14/07/06 06:16 AM Share Posted 14/07/06 06:16 AM No more AFL 1, I never thought the day would come. Every car I've ever owned had an AFL 1 oil filter. Link to comment Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 4m 10d Gender: Male Location: Melbourne, Victoria Posted 14/07/06 01:15 PM Author Share Posted 14/07/06 01:15 PM I have fitted one of these.Easy to do, just order the 'bits' from Ford (see attached).Just be careful to get the the right fitting to retain the cooler to the block. It must have the smaller 'old' size thread on the end where it screws into the block, and a slightly larger thread on the opposite end where the oil filter goes.pm me if you need more info.that's great, thanks for the help. I will certainly look into fitting one.BTW Did you find any improvement in engine temperature stability under load ?Thanks again,Robin. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 1m 19d Gender: Male Location: Perth, WA Posted 14/07/06 02:39 PM Share Posted 14/07/06 02:39 PM I have fitted one of these.Easy to do, just order the 'bits' from Ford (see attached).Just be careful to get the the right fitting to retain the cooler to the block. It must have the smaller 'old' size thread on the end where it screws into the block, and a slightly larger thread on the opposite end where the oil filter goes.pm me if you need more info.that's great, thanks for the help. I will certainly look into fitting one.BTW Did you find any improvement in engine temperature stability under load ?Thanks again,Robin.←Brand new modified engine, so I haven't stressed it yet.Don't think you will see any change on the gauge, as all the heat from the oil is absorbed by the cooling system, but I have no doubt that the oil will be running cooler inside the engine Pictures show cooler on the engine. Link to comment Share on other sites More sharing options...
