Remove Rear Bar
podrcr
  • Member For: 19y 4m 24d
Hi I watched the a guy remove mine when he fitted the tow bar. It was quite simple. If I new it was that easy I would of installed it myself.
You remove all the plastic clips under both rear guards, Around where your mud flaps get attached
Remove 2 x 8 or 10mm ( I cant remember what size) nuts that are located inside the boot space , under both rear light assembly’s.
Remove 2 x plastic clips, located under side of bumper ( near the towbar cutout ).
Then either side of the bumper bar end just pulls out, simular to the front bumper.( They are clipped to the side panel )
Once you “unclip the bumper end’s “ the bumper should then just slide out.
  • 1 year later...
  • 2 years later...
  • <put funny sh*t here>
  • Member For: 18y 2m 3d
how did you guys get the clips out? they flare on the insides and I dont wanna snap em?
I put a real small thin screwdriver in between the screw and the base of it, jam it in tight, then lightly unscrew the screw with a philips screwdriver. Try not to push it inwards too much as it makes it harder to undo the screw. Once its out enough to get a hold of, you can rip the screw out with pliers too if you want.
  • Member For: 18y 3m 15d
You remove all the plastic clips under both rear guards, Around where your mud flaps get attached.. Also the screw clips on the very top under that plastic..
Remove 4 x 10mm nuts that are located inside the boot space , under both rear light assembly’s. You will need a long head ratchet piece for the 2 bolts under the inner guard as the thread in really long
Remove 3 x screw clips, located under side of bumper ( near the towbar cutout ).
followed the original post and came with a few speedhumps.. I corrected it
  • 1 year later...
  • Member For: 15y 8m 13d
excellent write up, took mine off today with ease (apart from damn toe ball, but got around that ;) ) .....talk about stones and dust behind bumper...geez was like a falcon dump truck :D
