mattson Award Winning Photo guy Donating Members 1,340 Member For: 21y 5m 28d Gender: Male Location: Burleigh Waters Posted 09/07/06 09:52 PM Share Posted 09/07/06 09:52 PM Well, for the last couple of months know I've noticed my tyres are beginning to wear on the insides... well after three trips to the tyre shop they reckon it's because there's too much camber in the rears (probably due to being lowered and audio equipment jammed in there) none the less, they reckon they can't get anymore adjustment out of them.What I want to know is, what can I do to fix it? I wouldn't think I'm the first to have this problem?Let me know.Cheers,Matt Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/ Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 2m 11d Gender: Male Location: stanthorpe wine capital of qld. Posted 09/07/06 10:02 PM Share Posted 09/07/06 10:02 PM I don't get that problem matt is it front or rear that are doing it.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404331 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m 23d Gender: Male Location: Melb Posted 09/07/06 11:29 PM Share Posted 09/07/06 11:29 PM he mentioned Rears (and also hinted due to audio equipment)..If there's no more adjustment its due to not having camber kits in the back as well. (Yes, you can get camber kits for the back)..Alot of places when lowering your car do not put the kits in the back, they only do the front.. because when quoting their price is normally $300-$500 more expensive..Ie, one place quoted me $900 odd to lower car, camber kits all round, and another mod quoted $600.. I can tell you the lower price would not have the camber kits for the rear. I never knew rear camber kits were available until I asked the guy why is he more expensive.. When I called up the original $600 quote, he said "nah mate, there's enough adjustment in the rears to not require that". Weather that's true or not, I am going with the camber kit in the back on the consideration that they make a kit for the back indicating there must be a need for it.. And you have highlighted that saying that there is not enough adjustment for that.Danny. Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404341 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 10m 9d Gender: Male Location: Perth, WA Posted 09/07/06 11:59 PM Share Posted 09/07/06 11:59 PM I should get one for the fronts... my tyres have been scrubbing out on the sides since I got the car!! Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404348 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m 13d Posted 10/07/06 12:14 AM Share Posted 10/07/06 12:14 AM it pays to get a camber kit in any case, fords are well know to have wheel alignments that fall out of place and hence wear out the inners. Ive seen it on about 4 fords I known ppl to own, though the BA-BF range dont seem as bad. Either way 180 for a camber kit is cheaper than wearing out 600 worth of tyres 10000km prematuraly Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404354 Share on other sites More sharing options...
Bain Member 827 Member For: 20y 4m 5d Gender: Male Location: Melbourne Posted 10/07/06 12:29 AM Share Posted 10/07/06 12:29 AM Whiteline do camber kits for the BA.$75 for a set of 2.I have no clue why they would charge you so much to put them in (if they are doing your springs at the same time).. Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404359 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 10m 9d Gender: Male Location: Perth, WA Posted 10/07/06 12:33 AM Share Posted 10/07/06 12:33 AM Yeah my next wheel alignment will be done by a suspension joint. Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404361 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 7m 19d Gender: Male Location: Dé·jà vu Posted 10/07/06 12:34 AM Share Posted 10/07/06 12:34 AM The first thing Herrod offered me back in '04 when I had my previous car was a rear camber kit, he said at the time that it only needed a rear kit but having gone through a set of fronts from wear on the inner edge I'd be fitting one to the front as well. Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404362 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m 13d Posted 10/07/06 03:13 AM Share Posted 10/07/06 03:13 AM Whiteline do camber kits for the BA.$75 for a set of 2.I have no clue why they would charge you so much to put them in (if they are doing your springs at the same time)..←is that front or rear camber? cause I been quoted 180 for camber kits, not sure of the origin for front. Just supplied Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404413 Share on other sites More sharing options...
Bain Member 827 Member For: 20y 4m 5d Gender: Male Location: Melbourne Posted 10/07/06 04:32 AM Share Posted 10/07/06 04:32 AM Whiteline do camber kits for the BA.$75 for a set of 2.I have no clue why they would charge you so much to put them in (if they are doing your springs at the same time)..←is that front or rear camber? cause I been quoted 180 for camber kits, not sure of the origin for front. Just supplied←For either - supplied only of course. Its not hard to fit a camber kit.For 180 each set you are probably looking at Castor AND Camber kit.This was through Advantage Suspension (where I have bought all my suspension needs for current and previous cars) Link to comment https://www.fordxr6turbo.com/forum/topic/26720-too-much-camber/#findComment-404425 Share on other sites More sharing options...
