Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 8m 14d Gender: Male Location: Brisbane Posted 12/07/06 09:06 AM Share Posted 12/07/06 09:06 AM veczar said: Kimmy Scott if you dont want to get a new cluch then dont go for 250rwkw it will kill your stock one. Just go unichip/edit + 2ndCAI + K&N. Once you do injectors and cat your clutch will be teh slip master.Now, Back on topic ←I thought the 260-270rwkw was the mark for slipping clutches on T56?May all be a mute pont anyway, as I may be buying a house, so no money for the T.Scotty Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 3m 16d Gender: Male Location: Strapped in and holding on Posted 12/07/06 09:13 AM Share Posted 12/07/06 09:13 AM xr_jim said: what kind of power increse would I get by fitting a 4' magic cat? I have a stock BA MKI T. also would I come on boost earlier?←Hi mate. Because of the way the factory computer controls things, it will not allow just a cat fitment. The cat fitment will free up the exhaust, increase the boost and the engine management detects it, and puts the car into 'limp' mode, as it sees a problem.You will ALWAYS need to get the factory computer 'edited' or a secondary device attached to the computer to fool the computer into thinking there is no problem.Editing the pcm is easy, getting a good edit ( tune ) of the pcm is another story. The subject has caused many a war 'round these parts.... Link to comment Share on other sites More sharing options...
xr_jim Member 10 Member For: 18y 8m 21d Location: Newcastle Posted 12/07/06 09:30 AM Share Posted 12/07/06 09:30 AM thanks, where would I need to go to get it edited? anywhere in sydney you could recomend? what sort of cost are involved? Link to comment Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 9m 12d Location: Canberra Posted 12/07/06 09:46 AM Share Posted 12/07/06 09:46 AM xr jim, I posted above saying I had my 4inch cat installed with the car standard, and I can't say I noticed much. Car didn't go into limp mode, I think the ecu simply retarded timing, as boost remained at 4.5psi at WOT. To make the most of the gains, as mentioned you really need a custom tuned edit. I can't comment on the sydney side of things, but I'm sure some one will point you towards a good tuner shortly! Link to comment Share on other sites More sharing options...
xr_jim Member 10 Member For: 18y 8m 21d Location: Newcastle Posted 12/07/06 10:10 AM Share Posted 12/07/06 10:10 AM was there any noticeable performance increse? Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 3m 15d Location: nowhere in particular Posted 12/07/06 09:19 PM Share Posted 12/07/06 09:19 PM bugster70 said: Falchoon said: A bit exxy, just over $200, I know others have got it done for less. Noise doesn't really seem to have changed, maybe under full throttle/peak revs but I haven't had a chance to test that theory yet! ←Ross, where did you have it fitted mate? And which cat did you get, the 4" or 5"?And has the car been running okay since installation? No overboost/limp mode issues? I was just under the impression the factory ECU program may not be able to cope with the additional flow such a cat would provide - thought an Edit was needed? ←Powatone fitted it. I only had it installed for a day before getting all my other bits fitted and tuned so didn't really get a chance to give my car too much sh!t. Car has now quietened down slightly after the tune. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 12d Gender: Male Location: Sydney NSW Posted 13/07/06 10:07 AM Share Posted 13/07/06 10:07 AM Kimberley Scott said: veczar said: Kimmy Scott if you dont want to get a new cluch then dont go for 250rwkw it will kill your stock one. Just go unichip/edit + 2ndCAI + K&N. Once you do injectors and cat your clutch will be teh slip master.Now, Back on topic ←I thought the 260-270rwkw was the mark for slipping clutches on T56?May all be a mute pont anyway, as I may be buying a house, so no money for the T.Scotty← mine slips with only a CAI... and 5000kays on it Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 8m 14d Gender: Male Location: Brisbane Posted 13/07/06 10:58 AM Share Posted 13/07/06 10:58 AM RAP1D said: Kimberley Scott said: veczar said: Kimmy Scott if you dont want to get a new cluch then dont go for 250rwkw it will kill your stock one. Just go unichip/edit + 2ndCAI + K&N. Once you do injectors and cat your clutch will be teh slip master.Now, Back on topic ←I thought the 260-270rwkw was the mark for slipping clutches on T56?May all be a mute pont anyway, as I may be buying a house, so no money for the T.Scotty←mine slips with only a CAI... and 5000kays on it←that's no good mate, surely that would be a warranty issue, and not the norm though?Scotty Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 12d Gender: Male Location: Sydney NSW Posted 13/07/06 12:29 PM Share Posted 13/07/06 12:29 PM Nah, clutch isnt covered. It works ok for normal driving, takes up very high though... slips if I drop it at 4000plus when its hot Link to comment Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 8m 14d Gender: Male Location: Brisbane Posted 13/07/06 12:32 PM Share Posted 13/07/06 12:32 PM RAP1D said: Nah, clutch isnt covered. It works ok for normal driving, takes up very high though... slips if I drop it at 4000plus when its hot←I see, never been game to do something like that, still guess it is better the clutch slips that something goes bang.Scotty Link to comment Share on other sites More sharing options...
