Which Mod's Gives How Much Kw
mrits
  • CNUTOX
  • Member For: 22y 1m 1d
How long is a piece of string???
You won't get much cos of the ecu protection strategy. I am told from a very good source, that with the overboost reflash 12 months ago, the threshold was raised slightly. So with a bleed valve, you may be able to screw about 1-3 psi more, but it is trial and error.
Other than that, there isn't much. Airfilter etc will give you nominal, if any on a stocky, the exhaust is good as is.
  • Member For: 18y 7m 9d
so if I changed the exhaust that would increase power without and edit is that what your saying or it will, and if so what kind of power diff are we talking about.
  • Member For: 18y 10m 17d
it wont increase power as the stock exhaust is far capable of flowing the required gas at the stock engines power level. The real restrictions in the exhaust are the cat and dump pipe. they rear there ugly head at the high end of the 200rwkw range.
  • Seriously Flukey Member
  • Member For: 20y 10m 17d
I think Envy is saying the exhaust is good - there is no need to change it.
You could try a CAI and filter which might give you 5-6 kw's, but if you want noticeable change, get edit.
  • Member For: 22y 3m 27d
Nope, that's not how I read it. As I understand it the exhaust is already pretty good. You may achieve a handful of killerwhatsies by removing a muffler and fitting a second cold air intake. They are the cheapest mods you can do and won't gain much because as has been said there is an overboost protection system built into the ECU - if you attempt to open the intake or exhaust to any great extent it will simply go into overboost protection mode.
