blueprint Member 12 Member For: 19y 8m 11d Posted 02/07/06 10:50 AM Share Posted 02/07/06 10:50 AM Hi eyeryoneI'm trying to run new speaker wires to my front doors but I can't seem to find a way, cause factory wiring to the door is just a plug so I was wondering if someone could help me out. Also I was wondering where people have been mounting there tweeters.thanks Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 1m 24d Location: nowhere in particular Posted 02/07/06 11:15 AM Share Posted 02/07/06 11:15 AM Also I was wondering where people have been mounting there tweeters.thanks←The factory Premium Sound has the tweeters in the A pillar. Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 20d Posted 02/07/06 12:40 PM Share Posted 02/07/06 12:40 PM why dont you just splice the wires running from your amp into the original speaker wires running into the door Link to comment Share on other sites More sharing options...
cqae Member 229 Member For: 21y 3m 5d Posted 03/07/06 02:34 AM Share Posted 03/07/06 02:34 AM actually, running wires through that door rubber is quite easy. just pull back the rubber & ther will be plenty or room to poke through wires-might even be a 10mm bolt in there to undo- mine has a few spares ins but it might cos its a ute. Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 20d Posted 03/07/06 03:15 AM Share Posted 03/07/06 03:15 AM quick tip if your amping up some rear speakers in a ute re-enforce the mounting plate that ford give you, because it tends to rattle. Link to comment Share on other sites More sharing options...
DaRKy Member 13 Member For: 21y 1m 18d Posted 09/07/06 05:11 AM Share Posted 09/07/06 05:11 AM ok I've been at it all day and cannot manage to get wires thru those front doors ... pulled off heaps of crap, inside I can't even get to the plug cause of the sound deadening. how on earth do u do it Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 8m 21d Gender: Male Location: Sydney NSW Posted 13/07/06 09:50 AM Share Posted 13/07/06 09:50 AM You could just re use the orig wires, as thin and crap as they are it does make things alot easier Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 5m 17d Gender: Male Location: Perth, WA Posted 13/07/06 09:53 AM Share Posted 13/07/06 09:53 AM I wouldnt recommend it if you plan on using an amp. Higher current = more heat and with less copper that can be bad. It can also give u lower quality top end sound. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 8m 21d Gender: Male Location: Sydney NSW Posted 13/07/06 09:58 AM Share Posted 13/07/06 09:58 AM Sound qual would suffer for sure... heat wise its fine, unless your playing sine waves at full volume Link to comment Share on other sites More sharing options...
bob^ Member 170 Member For: 21y 3m 7d Location: Geelong Posted 13/07/06 10:33 AM Share Posted 13/07/06 10:33 AM (edited) Over such a short length of wire, the resistance would be minimal. You'd have to be running a lot of power to want to replace that part of the wiring. (70watts would equate to around 4amps, and since music is dynamic, those power levels would never be sustained unless playing sine waves)I'm running the stock wiring from just inside the kick panels, the doors, to my Dynaudio mids, and they sound just fine.Saying sound quality will suffer is quite a subjetive thing. Some people claim to be able to hear the difference between run of the mill cable, and their $1000/m cable. I'm not one of those people, and I never will be.I know of a particular award winning SQ car which uses the factory wiring for the short length. Guess his sound quality couldn't have suffered too much .My hands are too fat to get in there to run new speaker wire. I spent ages trying it.Other people have used the grommet just above the factory one in the bottom of the pillar, and then punched a hole in the rubber in the door and ran it through that way, but I'm not a huge fan of that. Edited 13/07/06 10:38 AM by bob^ Link to comment Share on other sites More sharing options...
